Question about Sony Handycam DCR-TR7000 Digital Camcorder
Sony 700x digital handycam
I have a sony 700x. I get a message when I turn it on sony infolithium system and then there is a yelloy triangle in the center of the picture. I cannot Standby or Record, and there is a number blinkin C:31:23.
  • 1 more comment
  • Anonymous Apr 14, 2008
    I have a sony 700x.
  • manuelagreim Nov 07, 2008
    error c 3123
  • Anonymous Feb 06, 2009
    where can i get the driver for this digital handycam?
  • 31 Answers
Error 31 is some kind of a problem with the cassette compartment, it's either won't eject it right now, or it's stuck otherwise. try to eject, if doesn't work, try "reset" button, if still no luck, replace the cassette compartment
Posted on Aug 21, 2007
I have a big probleme with my sony 700x Digital. there is a number blinkin C:31:42.
Posted on Jun 28, 2008
SOURCE:
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony 700X digital handycam
solution 1: Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. solution 2: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required. If your camcorder still shows the same error code, then you'll have to send in your camcorder for service additional info that might help: According to the manual, the error code C:31:xx:xx means an error that >the owner can fix by himself has occured and that by taking out the >cassette and replacing it or by disconnecting the battery pack and >fixing it back should solve the problem. Error "23" means: "S reel emergency during normal rotation", i.e. the problem is with the tape deck mechanism and specifically the supply reel.
Aug 21, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
While inserting battery Sony NP-FP90 in my Sony Handycam DCR HC46 , it gives error mrassage " use infolithium battery and camera switch off Pls help
You can attempt to fix an InfoLithium battery which has developed passivisation by a process of charging and discharging several times.
try this while the camera is turn off.
let me know the outcome.
May 11, 2011 | Cameras
"SONY 'InfoLITHIUM' SYSTEM" Error
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
May 07, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Problem with infolithium system
Are you using the supplied battery? Recharge the battery fully and try again.
Feb 09, 2009 | Sony Handycam CCD-TR517 Camcorder
Digital 8 sony handycam will not stay on with electrical power
Check battery placement connector, center pin has some problem and not sending info-lithium signal to camera system control.
You might need to replace this battery connector and this requires to open camera.
If you have some experience in camera repair, let me know to guide you further.
Dec 17, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Problem with sony 700x
Handycam should have came with software to install on your pc to capture and edit home movies.
May 19, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Error message while trying to record.
That is my "Welcome" screen. Mine beeps also. After the beep, I record or doing whatever i need to do. Maybe you're trying to start it faster than it requires (in other words, slow down).
ric
Jan 01, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
The LCD is flashing eject indicator with error no. C:31.23 ,So before that it was showing reinsert the caset
According to Sony, the 31 problem is one that requires a power reset of the camera. Turn off the camera, remove the battery, remove the AC adapter if it is in use and then wait several minutes before re-attaching the battery and/or power and turning the camera on again.
The 23 problem is a non-Sony InfoLithium battery. Apparently these smart batteries interact with the camera. According to Sony: "Replace the battery in the camcorder with a Sony® InfoLithium battery or connect the supplied AC power adapter."
Nov 21, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Sony Handycam DCR-TR7000 Digital Camcorder Logo
713 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
