Question about D-Link AirPlus DI-524 Wireless Router
D Link DI 524 Wireless Router
Recently, we had an outage. When our electricity came back on, our internet came on to our computer but not to the other 2 computers in our house. I called tech suppport at Adelphia and found out that it was probably my router. To find this out, they had me disconnect and reconnect cables. They said I would have to reconfigure. Does this sound right to you? Thanks, Sara Wathen
  • 98 Answers
It is possible. If, due to the power outage, you lost your router config, you are going to have to configure it again.
Posted on Aug 22, 2007
SOURCE:
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Switched internet provider, wireless router will not work
The router works the same with either dsl or cable modems. If the router was working with your other computers before, then it should work now, you don't have to change anything.
Aug 19, 2009 | D-Link AirPlus G DI-524 Wireless Router -...
I have a D link DI 524 802.11g/2.4GHz wireless router which I've
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Jun 14, 2009 | D-Link DI-524 4 Port Wireless-G Router -...
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
My D-link DI-524 Wireless router not working.
g´day m8,
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  "yes"
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Intermittent Loss of Wireless Capability after Power Outage
Try upgrading the firmware through the Routers Web Interface , and see if this will fix the problem otherwise the only other way around it is to do what you are currently doing and unplug and plug it back in, perhaps the AP was damaged as a result of a power surge , if the problem persists best bet is to buy a new one.
Apr 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Method of connecting Dlink wireless router DI-524 to computer
On the back there should be a reset to reset to default settings.
Mar 10, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
