Question about GE 27831GE2 Phone
Both phones don't work at same time
Both phones ring, first phone answered works fine, another person picks up second phone to join conversaion, presses talk, nothing happens. Acts like it is dead. Does not make difference which phone answered first, one plugged into wall jack or one not plugged into wall jack. Second one answered never works.
After reading fine print, that is how they are suppose to work. Only one works at time.
Posted on Aug 24, 2007
6ya staff
SOURCE:
My answering service picks up after 3 rings....how do i extend the answer time to 6 rings or so?? I have the 9417 CW
Ask your provider to change your voicemail to pick up in36 seconds instead of 18. Each ring is 6 seconds. Hope this helps
Sep 24, 2011 | Aastra Telecom Aastra 9417 CW Corded Phone
Re Panasonic KX-DT321 I have read the short instruction leaflet sent with the phone but can't make head or tail of how to set the answerphone to engage after a given number of rings. I work in a busy...
Start by dialing 500 on the intercom. If that gets you into the voice mail system, then you can dial *710x 500 # where x is 4 for No Answer and 5 is Busy/No Answer call forwarding. The number of rings before the forward is controlled by *713yy where yy is a time in seconds. Each ring cycle is about 6 seconds, so 24 would be a good number.
Leaving a message on your own phone? Dialing 500 gets you into your personal mailbox as an owner. Dialing #8 and your extension gets you into the VM system as a caller. (or it might be #6, I don't have my VM online today)
Of course, if you have an ESVM instead of the TVx system, then the procedure is entirely different.
Carl
Aug 06, 2011 | Panasonic KXDT321 Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How do you 3 way call on the LG vu. when i call the third party with the other person on hold it wont let me join them.
  1. While on the first call, dial the 10-digit number of the second person.
  2. Press SEND; the first person is automatically put on hold while the call is made.
  3. When the 2nd person answers, press SEND to create a conference call.
  4. If the second person does not answer, press the SEND key twice to end the connection and go back to the first person.
  5. To end both conversations completely, press the END key.
Jun 15, 2009 | LG Vu Cellular Phone
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
BT Freestyle 1500 Plus telephone
To bearshead16
If you have this phone still, I am willing to buy it.
Could you email on [email protected]
or phone me on 07912041959.
Thank you.
Oct 25, 2008 | Lands Phones
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
Caller Id not working, phone disconnects after 2nd ring
This problem turned out to be a phone company problem.
Jun 20, 2008 | Avaya Lands Phones
Open Questions:
See all GE 27831GE2 Phone Questions
GE 27831GE2 Phone Logo
110 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
