Question about Euro-Pro 416 Mechanical Sewing Machine
Upper thread getting tangled in the bobbin
This is my first time using a sewing machine, so please bear with me if this is an easy fix. I can stitch about an inch of material before the needle gets stuck. When I remove the material, the top stitch looks pretty good but the bottom stitch is loose and all over the place. When I removed the bobbin case, I noticed that the upper thread is getting tangled up in the bobbin case. I have followed the manual completely. Does anyone have any ideas for this clueless gal?
  • 1 more comment
  • lamarcianak Nov 11, 2008
    I'm also getting the same tangle mess. I tried switching the bobbin and it still happens! grrrr.
  • Anonymous Mar 18, 2014
    Ii can not get the bobbin to make a good stitch.
  • Anonymous Mar 24, 2014
    Fixed tangled material in teeth of machine
    , but now bobbin rattles when sewing
  • 202 Answers
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
I hadn't used the machine in awhile and had actually threaded the machine incorrectly, bu the T-N-T made me rethink each step.
Posted on Jul 31, 2010
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
When I sew the thread doesn't catch on the hook behind the bobbin case and leaves gaps in the sewn item as much as 2-4 inches. How do I fix it? Can't afford to take it to a repair shop. Thanx, Cindy
First, install a brand new needle. A bent/damaged needle will frequently skip stitches. Also, be sure you are using the correct needle for the fabric and thread you are using, ie do not use a ball-point needle on woven fabric.
sewing machine skip stitches Google Search
If you've tried all the suggestions and it is still skipping stitches, the machine may be out of time. Search for sewing machine timing or take it for service.
Dec 21, 2016 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
I have just purchased an LSS-505 machine and I have not been able to get sewing yet. The bobbin thread tangles after about 3 stitches. I have done all the troubleshooting that I know to do, changed n
YOUR BOBBIN IS TOO BIG, when the upper thread passes over
to create the stitch it catches on the rim of the bobbin. Make sure there is no lint caught under it or in it's cradle.
Oct 14, 2014 | Michley Electronics, Inc Lil Sew & Sew...
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
Oct 11, 2017 | Brother Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Feb 01, 2013 | Sewing Machines
Euro-Pro 416 Mechanical Sewing Machine Logo
399 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
