Question about Motorola Mobility HS850 Consumer Headset
Motorola HS 850 Mic is not working.
I bought a new HS 850 Black bluetooth. It worked great for a couple of weeks and then Mic is not working. I am able to hear the other party's voice but they are not able to hear me. I have tried by pairing again. Not worked out. Pls let me know the resolution if you know, that will be really useful, thank you.
  • Anonymous Sep 01, 2008
    i can't pair to my blackberry
    Problem Solver:
  • 15 Answers
Perhaps it is in "mute mode" which can be activated on the headset itself by simultaneously pressing both the up and down volume buttons. Also, have you tried deleting the device from the phone you are using before you pair it up again? finally is there any firmware/software update available for the phone? This can be the case frequently with bluetooth problems with Blackberry devices (I know this from painful experience with this same headset). Good luck.
Posted on Aug 29, 2007
I don't remember the passkey for my hs850 bluetooth and 0000 disnt work. How do you reset it?
The passkey is 0000 and cannot be changed, did you follow the correct procedure ?
To place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone.
When it asks for a PIN, use 0000.
Dec 29, 2010 | Motorola Mobility HS850 Consumer Headset
How to set up motorola headset HS 850? Bluetooth
Here is the PDF version of the manual...
http://www.motorola.com/support/v/index.jsp?vgnextoid=0dc86d4a3590e110VgnVCM1000008406b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
Mar 08, 2010 | Motorola Mobility HS850 Consumer Headset
Motorola H710 mic not working
i pinched the flats sides of the boom together tightly and used my ps3 to measure the clarity and went from mic not working to semi to full clarity
Jul 02, 2009 | Motorola Mobility H710 Bluetooth Headset
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
Apr 10, 2009 | Motorola Mobility S9 Headphones
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola s9 mic does not work
try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). Mic stopped working after 2 weeks and removing the BT device and repairing did the trick.
Mar 11, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
Aug 05, 2008 | Motorola Mobility Bluetooth Hands-Free...
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
HS 850 won't go into pairing mode
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
Feb 29, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
163 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
