Question about Nokia N80 Cellular Phone
White sreen!! iv had my n80 a while now and lately every time you go to use the phone the screen goes totally white and cannot see anything for ages untill the screen comes back on, at first it was the odd time and now its everytime you go to use it
Re: white sreen!!
I think its the ribbon conecting the mainboard to the lcd screen as the phone still starts up and you can still use your phone apart from seeing what you are doing nokia n80 are renound for this problem
Posted on Jan 07, 2008
Re: white sreen!!
My friend has the same problem and she has had the phone for a while and its been through a lot ... i dont know if your phone is in good condition but i'd just take it to the phone store and tell them. You'll probably just get a new phone.
Posted on Aug 22, 2007
0 characters
3 Points
My phone is already white N80
White screen are symptoms for Contact retailer. try to call 112 (emergency call) if its working, meaning it's LCD problem. If 112 working try to clean the terminal of LCD. IF this doesn't work consider replacing it.
Sep 09, 2011 | Nokia N80 Cellular Phone
My n80 has a white screen..can same one help me..e
one of 3 reasons, flexi, lcd or upper keypad, first try to change the flexi, most of the time it is fixible from this
Jun 26, 2009 | Nokia N80 Cellular Phone
My N80 bring a white screen when i slide my phone
if you phone is less than a year old take it to car phone warehoue there will sort it out for free if not it will cost around 45pound ths pls rate
Mar 30, 2009 | Nokia N80 Cellular Phone
My Samsung M520 slider screen goes white and freezes
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Jan 23, 2009 | Samsung SGH-E900 Cellular Phone
Nokia N80 Lcd screen
its a problem with ur Glex cable its the faulty part ion this case.
Dec 20, 2008 | Nokia N80 Cellular Phone
Slide up, screen goes white but keys are active...
The strip that connects both the upper and lower slider is damaged ... replace it
Dec 11, 2008 | Nokia N80 Cellular Phone
My N80 doesn't boot, white screen only.
try to remove the memory card and try again to switch on..if not worked,then ur boot IC may be corrupted...
N80 White Screen
white screen?? but still your phone boots fine?can you still receive call or text msg? if soo, your only problem is the lcd of your phone,
but if your phone freeze on white screen and didn't continue to boot up, try reformatting it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
but all your data will lost
Sep 01, 2008 | Nokia N80 Cellular Phone
Display problem in Nokia N80
It's a problem with the wiring that connects the upper part of the phone to its lower part when you slide it up. The wiring apparently gets damaged easily and you need to have it replaced, the wiring only, not the phone. This has also happened to me and I sent my phone to a certified Nokia Service Center. They replaced the faulty wiring but since my phone was still under warranty, they did not charge me anything. Hope your phone is still under warranty. Good luck.
Jun 13, 2008 | Nokia N80 Cellular Phone
Nokia N80 problem
my problem with n80 is  next  when I open the slide the screen become like in 256 colors then i push the camera button and its come back to normal until i use  the phone when i close the slide the problem start again.What to do?
Jan 29, 2008 | Nokia N80 Cellular Phone
Cell Phones Logo
148 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
