Question about HP Compaq Presario 6310US (DA201A#ABA) PC Desktop
Presario Board 6310us JP Pins
Hi, What pins should we jump for what? Thanks, Maureen
    Novelist:
  • 231 Answers
Please be as exact as you can about what you are trying to achieve here, anyone of us offering advice could reccomend a hundrend different jumper settings and not be answering your needs. Get back to us asap and I am sure we will be able to help. Regards mistyman
Posted on Aug 23, 2007
  • 40 Answers
You need to be more specific with a problem..
Posted on Aug 22, 2007
SOURCE:
Hi i have a samsung plasma tv Model:pn51e530a3f what do i do if i have no power goin to the console yet i have just installed a new power control board. No vs or va readings r present
You might of bought a board that you don't need. This is what you do. Remove the power cord. Disconnect the cable that connects the power board to the main board from the main board. Also disconnect the cable that the connects the main board and the logic board from the main board. Now you want to jump pin 1 to pin 3 on the cable that goes to the power board. Look at the logic board. Do you see a set of pins on the board 1-4 or 1-6? You want to jump the 2 highest pins togeather. After you have done this, plug in the ac cord. Do you get colored patterns? If you do, replace tha main board. If you do not, check your VA and VS voltage while the set is running. More than likely you VS is missing. That tells you that your Y sus, Upper or Lower Y buffer or panel is shorted. I hope this helps.
Apr 08, 2016 | Samsung Televison & Video
Need multimedia drivers for compaq presario 6310us computer?
Audio Driver :
ftp://ftp.hp.com/pub/softpaq/sp22501-23000/sp22521.exe
Video Driver:
ftp://ftp.hp.com/pub/softpaq/sp22501-23000/sp22532.exe
Jan 02, 2011 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Compaq presario sr2011wm desktop push power on button and the computer won't come on. tried unplugin powercord and waiting for ten seconds and still didn't come on and I've tried removin and restalling...
the psu is bad.
the test is easy , one jumper wire prove PSU bad.
if its fan is dead, (and all fans )
jump pins 16 to 17 (power on pin jumped to ground 17)
connector pulled, turns it on.
see here. and why
http://www.pcdied.com/power.html#Jumper
Sep 16, 2017 | HP Compaq Presario SR2011WM PC Desktop
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to [email protected] , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Compaq 6310US: Can't get into BIOS
you can try removing and replacing the battery on the motherboard. If that does not work, you will have to look for the reset jumper on the board.
May 02, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Master reset for pc
Unplug your machine from wall outlet. Open the case and remove the flat battery from the motherboard. Wait 5-15 minutes and replace it, your machine is now at default settings.
If this helps plz take the time to write a couple of word testimonial. Thanks.
Oct 19, 2009 | Compaq Presario 5000 PC Desktop
What is wrong when the color on my tv is jumping in and out.
U have cold sholdier joint at the vidieo board connection pins or the crt yoke pins connection to the main pcb board.If u unlucky the video board ic is short or dying
Aug 17, 2009 | Televison & Video
Hard drive wont come out of compact presario 6310us
You need to take off the face of the computer. There are six plastic tabs inside the computer that you can press down to remove the face. Once it's off, you can slide the drive out the front.
Let me know if you have any other questions. I'll monitor this thread.
Jason
Jan 27, 2009 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Downloading photos from the mobile to my laptop
on the k800i it at the bottom where you use the charger insert the part like two pins .and then put the usb in to pc.
riz.
Mar 21, 2008 | Sony Ericsson K800i Cellular Phone
Hi i have a 93
The jumper looks like a staple from the top side . It is soldered to the bottom of the board. The copper trace can be followed from pin 2 through the staple ( jumper ) to pin 6 of IC 2004. Remove the staple ( unsolder from the board ) then solder the staple from pin 6 to pin 7 of IC 2004. The IC has a notch at one end. Pin 1 is the first pin to the right of the notch looking down on it from the top. The pins are in consecutive order 1,2,3 etc. Hope this makes sense.
Mar 12, 2008 | Televison & Video
HP Compaq Presario 6310US (DA201A#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
