RIM Blackberry Playbook can be unlocked using unlock code. You can get unlock code for cheap price from unBBlock.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Blackberry Playbook .
SOURCE: to unlock rim BlackBerry 7290
http://www.unlockitnow.com/Blackberry http://www.unlockanyblackberry.com/
SOURCE: Unlock BlackBerry 7290
Unfortunately, the unlock code for a BB 7290 is unique to each phone. The unlock code is based on the IMEI of your BB. After getting an unlock code then the steps to unlock are:
1. go to options
2 scroll to SIM CARD then press jog dial in once to select it
3. Type MEPD (not case sensitive) ( you will not see text appear on screen while typing )
4. Does it say Network active? if so your phone is locked
5. Press and hold the alt key (half moon looking key on the lower left side)
6. as you are holding the alt key type in MEPE (not case sensitive) ( you will not see text appear on screen while typing )
7. type in the unlock code when prompted
8. After entering the code press the jog dial in
9. Your phone is now unlocked!
SOURCE: How do I unlock this phone?
Try pressing the alt key and enter six 0's....then call your cellphone,that is how I reset mine.
SOURCE: unlock code for rogers blackberry bold
It's a clear and fully detailed guide on how to unlock a BlackBerry Bold:
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done .
SOURCE : BLACKBERRYMEP.COM
