Question about Garmin zumo 550 GPS Receiver
Zumo 550 Hello, My Zumo 550 was connected to my pc. Did unplug the cable, and doesnt work any more. does not start up... Help!!!
  • Anonymous Mar 29, 2014
    default setting
My Zumo would not start after a normal shutdown. I removed the battery and left it for a few minutes, reconnected battery and it started OK. I guess it locked up for some unknown reason.
Posted on Aug 28, 2007
SOURCE:
I unplugged cable to computer during first update This is a garmin zumo 340
Try doing a Hard Reset
  • hard reset zumo 340 en 350 - YouTube www.youtube.com/watch?v=tWUDsiXu9QI
    • BY MRGPSNL
    • 6 MIN
    • 10K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer ... hard reset zumo 340 en 350 ... Garmin Zumo ...
  • zumo 340LM ' Garmin buy.garmin.com > Shop > Automotive > Motorcycles Garmin Connect lets you search, plan and share your rides. Get Started /en-GB/GB/accessoriesAndMapsUrls/010-01043-06.ep. Customer Service. Product Support;
  • Hard reset Garmin Zumo 220, 550, 660 - YouTube www.youtube.com/watch?v=g9h9QtWWedk
    • BY MRGPSNL
    • 4 MIN
    • 25K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer 'als nieuw ... Hard reset Garmin Zumo ...
  • Garmin zumo 660 665: How to Reset Video - GPS City www.gpscity.ca/videos/play/Q0td7d4BH9A How-to video for the Garmin zumo 660 665: How to Reset Video explaining its functions and installation.
  • http://www.bing.com/search?q=garmin+zumo+340+reset&qs=n&form=QBRE&pq=garmin+zumo+340+reset&sc=0-21&sp=-1&sk=&cvid=3C4EE77095704DEC935AD44372BE0B4D
    May 11, 2016 | GPS
    Zumo 550
    is the battery working fine.
    Oct 21, 2008 | Garmin zumo 550 GPS Receiver
    When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
    Hi tkfranks331,
    Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
    If this does not work, please follow these steps.
    1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
    2. Open WebUpdater on the computer.
    3. Connect the Zumo 550 to the computer with its USB cable.
    4. WebUpdater will automatically search for updates.
    5. Follow the prompts to download any pertinent updates for the Zumo 550.
    Hope it helps.
    Thank you for using FixYa.
    Aug 17, 2011 | Garmin zumo 550 GPS Receiver
    HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
    If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
    1. Connect the zumo to a power source such as a computer or AC outlet
    2. Hold the zoom (+) and ON buttons at the same time for five seconds
    3. If this does not restore power, remove the battery for five seconds
    4. Place the battery back in the zumo
    The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
    Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
    Good luck,
    Michael
    Feb 01, 2011 | Garmin zumo 550 GPS Receiver
    Can't end Bluetooth phone call with Zumo 550
    I have a motorola phone, and it's fine.
    I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
    Check the phone is set up this way, and all should be well.
    Hope this helps.
    Dec 24, 2008 | Garmin zumo 550 GPS Receiver
    Garmin zumo 550 vehicle file
    Instructions taken directly from the Garmin website
    How to Install:
    1. Connect your Garmin GPS device to your computer.
    2. Click Download.
    3. Click Open, if necessary.
    4. Click Extract.
    5. Browse to find the “Garmin/vehicle” folder on the Garmin drive. You may need to create the vehicle folder.
    6. Double-click the Unplug or Eject icon in your system tray. Click Stop, and then click OK.
    7. Unplug the USB cable from your Garmin GPS device.
    Jul 28, 2008 | Garmin zumo 550 GPS Receiver
    Garmin zumo 550 bluetooth pairnig problem
    Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
    Mar 28, 2008 | Garmin zumo 550 GPS Receiver
    Zumo 550 - Failure of call functionality on Bluetooth
    Try the garmin webupdater with the unit connected to the computer to see if your bluetooth firmware is the latest. Beware however, I lost phonebook functionality!
    Mar 04, 2008 | Garmin zumo 550 GPS Receiver
    Connection problem between a nokia n95 8gb and zumo 550
    I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
    1) Assuming the N95 and Zumo are paired via BlueTooth
    2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
    3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
    4) Select the Zumo 550 device from the list of paired Bluetooth devices
    5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
    Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
    Feb 15, 2008 | Garmin zumo 550 GPS Receiver
    Lines Running North and South
    How do you load maps? and are these Garmin maps. I try to keep the Zumo original and use an SD card for extra maps. Did you try this yet? And if you are using SD cards, try a different brand/quality. I had some lockups with crappy budget cards. Kingston, Sandisk and some other A brands work fine!
    Oct 16, 2007 | Garmin zumo 550 GPS Receiver
    Garmin zumo 550 GPS Receiver Logo
    241 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Jean-Luc Steffann
    Sheldon Dedek
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
