Question about Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009
ThermalTake CL-W0009 Water Level Indicator
Hi, I have a ThermalTake CL-W0009 Water Level Indicator and i cant fit it because i use TYGON Thick walled tubing and cant get the nuts over the tube,I could fix it if i could replace the fittings with hose barbs but cant find any info on what size the thread is on the thermaltake fittings once i know that i can fix the problem Regards Andrew
They are standard 1/8 bspp fittings i have solved it allready by using a 1/8 to 1/4 bspp adapter this means i can use what ever size hose barb i want its all fitted and running with the tygon tubing thanks for you help have a nice day from the U.k.
Posted on Aug 23, 2007
  • 625 Answers
Those tubing fittings on it are the quick disconnect type. use regular tubing black polycarbonate. go to mcmaster carr industrial supply and get what you need. from the looks of it they seem to be 1/8 inch npt thread
Posted on Aug 22, 2007
Looking for a diagram of waterpump on a 1999 cadillac deville concours 4.6 liter
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the coolant.
  3. Remove or disconnect the following:
    Negative battery cable
Upper fill panel, if equipped
AIR injection control valve, if equipped
Air cleaner
Oil level indicator tube nut, if necessary
Water pump belt cover
Water pump drive beltLower radiator hose
Thermostat bypass hose from the coolant inlet housing
Water pump cover
Remove the water pump by rotating it clockwise using special Tool J 38816-1A (water pump remover/installer).
To install:
Install the water pump with a new O-ring, by turning it counterclockwise using the special tool, until it stops. Torque the water pump to 73 ft. lbs. (100 Nm).
Install or connect the following:
Water pump cover. Torque the bolts to 89 inch lbs. (10 Nm).
Lower radiator hose
Thermostat bypass hose to the coolant inlet housing
Air cleaner
  • Refill and bleed the cooling system.
  • Run the engine and check for leaks.
  • Oct 04, 2017 | Cadillac Cars & Trucks
    Leaking water on floor
    Look for:
    (1) Condensate drip pan under the refrigerator (catches & evaporates water from defrost cycles) may be out of place or leaking.
    (2) Drip Tray under water/ice dispenser may be overflowing (drain may be clogged, if so equipped).
    (3) Leaking water supply line (to ice maker/water dispenser): Check:
    (a) at inlet-valve fitting(s) and along all tubing going to ice maker & water dispenser,
    (b) at water filter connections (check inlet & outlet fittings and any gaskets where filter is inserted,
    >>> Tubing can develop a pinhole leak or crack if bent too sharply, pinched when unit is pushed back against a wall, contacting hot or vibrating parts (e.g. compressor or fan),
    >>> If connections are the "push-on" style they can leak if the tubing is not cut off squarely - with no burrs, pinched, cracked or distorted ends (use a sharp knife or tubing cutter)
    >>> If compression fittings are used with polyethylene tubing a ferrule must be inserted into the tubing end to prevent the tubing from distorting as the nut is tightened; also over-tightening nuts or reusing old compression rings under the nuts may cause leaks.
    * Remember to vacuum out the dust bunnies from the fan, condenser coils and all air vents while you're poking around under the fridge!
    Nov 19, 2012 | Samsung RM255LASH Side by Side...
    It leaks water from underneath
    If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I would suggest that you pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's2_bing.gif and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
    May 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Thermaltake aquarius III LCS not working
    Pumps wear down eventually i am not sure if they can die from storage though. you can get a new one for not that much. But they cerainly wear down as anything with moving parts does.
    Feb 21, 2010 | Aqua Thermal Take Inc. W2 CL-W0088 Brazing...
    20 metric cups equal how many liters
    Never heard of that measure, but a 'standard' cup is 250ml. So 20 x 250 = 5 Liters.
    Feb 09, 2010 | Thermaltake Liquid Cooling System Water...
    Dry rotted tubing on my weedeater blower.
    Have it replaced at a lawnmower repair shop.
    1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
    Aug 23, 2009 | Garden
    Do not overfill your reservoir tank!
    Scheck see if your fan is running regularly and strong. If it's not, then cooling won't happen and it will shoot water every time.
    Water pumps can also cause such problems in when they fail.
    Feb 19, 2008 | Thermaltake Liquid Cooling System Water...
    Silent pc
    Really depends on your price-range, and to what extent you are looking for "results", to simply make your PC a 'silent', a less expensive one, (ave.$80USD), should work, such as many "COOLMASTER" ones, I have one of these #201(?), and it has the 5"1/4" drivebay LCD panel, works quite well, keeps my Prescott (read "pres-HOT":) (3.0GHZ), down around 70o (versus ave. of about 120o, that ran for about $90 a year ago.
    On the other hand, you could Never go wrong with a 'full-blown' "KOOLANCE" system/case. . such as "external water pump & container", although, these range in the 100'sUSD, many time $500+. .
    Either way, Water Cooling, IMHO, is the best. .
    Keep in mind that a lot of PC's 'noise' actually comes from the Hardrives, although, depending upon your case/setup, this may or may not bother you.
    Also, a Good "Sound Dampening" case, or even just the "sound dampening "harddrive covers" work well.. try a Google search for MANY reviews, and product info; simply use;
    "water cooling cpu", is a great start.
    Let me know if there is anything else about these that you may be wondering, I have had mine running "practically" 95% of the time over an entire 2 years, only requiring a "refill" of coolant about* every 6 months or so. . Evaporation is slightly due to the extreme heat in the room in which my PC is located also tho.
    You may also find many opinions on using TEC (Thermal Electric Cooling" devices, enabling you to actually Drop the CPU's to Sub-Zero temps.. but that is usually only preferred tby the 'extreme' Overclockers'. .at any rate.. Good Luck!
    Dec 17, 2007 | Thermaltake Liquid Cooling System Water...
    Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009 Logo
    263 people viewed this question
    Top Thermaltake Computers & Internet Experts
    Martin Clarke
    Martin Clarke
    Lawrence Oravetz
    Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
