Question about Lexmark Wheelwriter 1000 Typewriter
Lexmark wheelwriter 1000
When i turn the typewriter on it just beeps and no light comes on
  • jorun Aug 27, 2007
    The two ribbons is secured properly; however when I lift up the keyboard I see a white cable ribbon that is only attach to the board a few inches right of the center point. The other end is hanging loose, I see two white connection to the far left of the board nothing is attach. None of the 4 led lights on the far right of the keyboard comes on.
  • Anonymous Mar 12, 2014
    MY IBM 1000 TYPEWRITER BEEPS ONCE
  • 328 Answers
Check the keyboard connections. Open the top cover and look just below from the top. You will see two ribbon cables. Make sure they are fully inserted. Are any of the keyboard lights flashing?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 26, 2007
  • Jay Blair
    Jay Blair Aug 27, 2007
    You have to reconnect the cables. In the four corners unmderneath you will see slots. Push a small screwdriver up inside and gently pry the release pin out aqnd at the same time lift the cover. Do this for all four corners and remove the complete cover asm. You can now reach the cables and connect them.
SOURCE:
Wheelwriter 1000 suddenly dead
No lights or beeps? Probably the power supply or popwer cord.
DickyO
Aug 21, 2012 | Lexmark Wheelwriter 1000 Typewriter
After my Wheelwriter 1000 is unplugged or turned
It sounds like your keyboard is going bad. You can try my tip under WW1000 or you can contact Geo. Beyers Co. @ 800-392-8085 for a rebuild.
DickyO
Jan 06, 2010 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 beeps when I try to type!
Could be a few things, board, power supply, keyboard or printer.
But there are some things you can check, remove the printwheel and look for debris in that area, unplug and replug the keyboard, if you are really adventurious remove the cover and keyboard and look for paper clips or staples on or under the pc board.
DickyO
Aug 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
I HAVE BEEPING ON MY WHEELWRITER 1000 ON LINE SPACING 1 & 2
The keyboard is probably bad and the typewriter can't see it.
Contact George Beters CO. 1-800-392-8085.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 typewriter has stopped working
sounds like your on/off switch has went. seen this several times.
good luck,
razors
Feb 09, 2009 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 1000 by Lexmark
Make sure the Lang feature is off. Use the code key witrh the lang key to turn off. also take all caps feature off.. Lawrence
May 07, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 (IBM) beeping
You may have the R. margin there. Space all the way to the right, press R MAR key. You also could have spellcheck on code 1 will turn it off
Jan 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000
there should be 4 led lights on the right side of keyboard. what is the flash pattern?
Aug 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
