some cod
Lg old and New
LG Chocolate =2945#*#
lg kf700 =3845#*700#
lg ku250 =26911147#*250#
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
KF310 kF311 reset codes
Test menu: 3845#*310#
for kf311 3845#*311#
engineer mode: 364663#31
menu : 2945#*#
This procedure is for LG CT810.
To RESET your phone back to factory defaults which will erase all current content and revert the device back to original shipped configuration:
1. Turn off your phone,
2. Remove the back panel and take out the battery for about 30 seconds,
3. Put the battery back into the device and replace back panel,
4. YOU MUST PRESS AND HOLD THE FOLLOWING BUTTONS SIMULTANEOUSLY!
a. Left Volume Down Button, AND
b.Right Camera Button, AND Power Button
5.Hold them until you see the green Windows Mobile startup screen and then you can let go,
6. After a few moments, you should see the initial screen caliberation screen,
7.Your device is now RESET/RESTORED to Factory Default (this assumes you have not applied a custom ROM, in which case the reset will simply go back to the defaults of that package)
LG XENON Reset.....Security Solved!!!!
Lg security solved!!!!
Hi there, follow the steps below for LG XENON
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
done it already
Pics Here
LG KE850 ***** security
without and with simcard: 1475369586#*# try this one too: 338464#*# ,then go Reset or restore default.
LG KU800 reset code = 277634#*#
kf311/310 =no sim inside
3845#*310#
KT520 user code reset =338464#*#
