Question about Cuisinart DGB-600 Coffee Maker
Coffee will no longer grind.
We just discovered this problem this morning. I put the coffee beans into the grinder, added the water, and was greeted by a loud spinning whine, instead of the loud spinning of grinding coffee. I took the beans out of the grinder basket, put the cover on the grinder basket, closed the lid and pressed the on switch. The blades turn. I then added enough coffee beans to make 4 cups. The blades sort of went around, but in no way did they grind the beans. What should I do now?
  • 1 more comment
  • Anonymous Mar 15, 2014
    I plug in the coffee maker and turn it on and the grinder stays on and won't turn off
  • Anonymous Mar 16, 2014
    Partially grinds beans and leaves beans in grinder
  • Anonymous Mar 17, 2014
    Beans are mostly ground, but some coarsely ground still in grinder. Also, the grinder blades seems very loose.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Posted on Aug 24, 2007
Where does the water go
This is a COFFEE GRINDER. Designed to grind coffee beans to into a powder . This powder is then put in a coffee machine or a coffee peculator to brew coffee. DO NOT put water into the coffee grinder !
Dec 19, 2010 | Breville Conical Burr Coffee Grinder -...
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Coffee Beans do not grind
Try using the vacuum to clean out the grounds, then remove the brew unit and make sure the chamber from the grinder is clear.
Aug 11, 2009 | Saeco INCANTO DELUXE Espresso Machine
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Cuisinart DGB-600 Coffee Maker Logo
647 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
