Question about Ricoh Aficio 450 Copier
Haloo I'm roumanian.i have an aficio 450 and when I change the ip what are the 6 number when press diamond button?there are the ip number?but the ip have more then 6 number?thet 6 number it's possible an password?please help me dr boble ore somebody else
No. Just leave out the 'leading zero's' in the ip address. for example: if your ip is .... 10.001.06.11 type in only 10.1.6.11
Posted on Sep 27, 2007
SOURCE:
How to delete web password off aficio mp c305 spf?
Type in the printers IP address. If you don't know it, go to user tools, the button with a diamond shape and a 123 on it. Go to system settings and then interface. Press the print list. It will give you 3 pages, only the first page is important. Search for IPv4 and type that into your web browser. The login details are admin, admin.
Jul 24, 2014 | Ricoh Aficio MP-C305SPF Color Copier :...
Tip
How to change the IP address on a Ricoh Aficio C811 printer
With the use of a DHCP (Dynamic Host Configuration Protocol) server, you can automate the administration of IP addresses for printers. However, you may want your printer to have a static IP address. To set up a static IP address on a Ricoh Aficio C811 color printer, follow the steps below.
1. When the printer is powered on and ready, press the Menu button.
2. Using the up or down arrows, scroll down through the menu to Host Interface and press OK.
3. Scroll down to Network and press OK.
4. Machine IPv4 Address is the first option on the network menu; click OK when it is highlighted.
5. You will see two options -- Auto-Obtain (DHCP) and Specify, and below them are three tabs -- IP Add., Subnet M, and Gateway. Scroll down so that Specify is highlighted, and then press the arrow button below the left-most tab (IP Add.).
6. Using the up and down arrows to change the numeric value, enter the IP address you want to use for the printer. Use the side arrows to go to the next part of the address once you've entered the value for the current octet.
7. Once you've entered the complete IP address, press OK. (If you want to cancel out without saving the new address, press Escape instead.)
8. If you need to specify a subnet mask and gateway address, you can enter those values in the same way, by selecting each of the corresponding tabs on the IPv4 menu (Subnet M and Gateway, respectively).
9. After you've entered all of the information and saved each address, make sure Specify is highlighted and press OK. You should see "Programmed" displayed on the screen.
10. Turn the machine off and then back on to apply the changes and reset the network connection.
on Mar 17, 2011 | Ricoh Aficio SP C811DN Laser Printer
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
How can I change the ip address for Richo Aficio 1035, I want to access this machine for printer use through my internet hub. Can anyone help please. Thank you
ok mate. follow the steps below to change the ip address.
-press user tools button
-press system settings icon
-press interface settings and you will see the ip address section, click on it and you can change it.
Nov 27, 2010 | Ricoh Aficio 1035 Copier
I need to reset the terminal name and number on the fax portion of the Ricoh Aficio 450 copier. Can anyone assist what that?
The fax user manual for the 450 is no longer available from Ricoh, so I can't check for sure, but the basic procedure is to press the User Tools button, go into Fax Features, and under one of the tabs will be a box where you can change the fax header information.
Hope that helps!
May 25, 2010 | Ricoh Aficio 450 Copier
Functional problem
Press next buttons by order :
1. press the yellow button [C] (cancel)
2. press the follow number on the number pad 1-0-7
3. press and hold the red key [C] (stop) until on the screen appear service menu.
After the service menu will appear turn off and then after 5 seconds turn on the machine from the main switch which is located down in the left corner under the front door.
Dec 14, 2009 | Ricoh Aficio 450 Copier
Have a ricoh aficio 450 and there is error code sc 623?
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Dec 17, 2008 | Ricoh Aficio 450 Copier
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio 450
Press the diamond button to the left of the display then press number press next until you see number 6 marked configuration then press number2 tcp/ip input your ip and subnet press the #button to set the data cheers dr bob1
Mar 22, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
