I have the Jacuzzi Water Rainbow Tub Faucet T582/T581-805 on my Jacuzzi tub now, but it is all worn out. I need a new one, or can I send this one for repair. Thank you, will wait to hear from you. BJ
SOURCE: Faucet placement on Jacuzzi 6036
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like.
SOURCE: I have a new Jacuzzi
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
SOURCE: My jacuzzi tub motor will hum but does not run. I
Turning the motor manually (with a wrench in my case (Jacuzzi Magnum Plus)) worked for me, now the pump is pumping happily away, thank you!
