Question about Sylvania 6520FDF 20" TV/DVD
Remote Help...channel setup
I just got cox cable set up in my house and they said i need to set my tv to Auto Program then choose Cable and not Air when that comes up. The only problem is that I can't figure out how to do that. PLEASE HELP!! My tv only goes up to 22.
What type of set is it?
is it cable ready?
do you have a remote or only front panel buttons?
Posted on Oct 24, 2007
SOURCE:
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Remote wont switch over to antenna cable or air for auto program 32in samsung hdtv
your remote doesnt switch,your tv does,in settings b4 searching for channels,choose cable or air
Jun 04, 2015 | Samsung Televison & Video
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
Mar 18, 2011 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Can't receive channels above channel 28
Try doing a " auto tuner setup" from the set up menu,
Select "Menu" from the remote and step through to "Auto Tuner Setup" choose CABLE or AIR and press "START". when done message will appear.
Jan 03, 2010 | JVC AV-32D305 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Program channels
Just Press Menu> scroll or Navigate or Select Auto program, then press enter> (to Move press volume button -minus or +plus,and to enter or OK press TV / VIDEO) then select auto program to automatically scan channel. Choose Air if you use outdoor antenna,if cable choose Cable,whatever the result ,just post so i can assist..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Changing to "Cable" from Antenna without a remote
if you have a cable box, just put the tv on channel 3,or a aux input.[depending on your hook up] if it's cable without a box,go to the menu setup screen on the tv look for a air/cable setting, choose cable. then do a auto program search.
wg
Feb 16, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Sylvania 6520FDF 20" TV/DVD Logo
269 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
