Question about Mitsubishi WD-52525 52" Rear Projection HDTV
New Lamp Replacement, still a No Go.
Mitsubishi WD-52525 52 The Lamp does not come on and I do get red light indicating the Lamp is bad. With a new Lamp installed it still does not come on. I measured 70 volts on a DVM inside the TV where the Lamp should plug in. 70 Volts can't be a correct output. I do not have any schematics. Can someone shed some light on what might be wrong ?
  • booboo4008 Feb 27, 2009
    I have a Mistubishi WD-52525 and am trying to replace the lamp. My instruction manual shows something different than what my TV actually looks like. How do i get to the old lamp to replace it with the new and do I really need to unsrew EVERYTHING on the back basically.. I am really lost and need help.
  • Anonymous Feb 27, 2009
    where can i get lamp driver 52525 model?
I had a similar problem when I change out my lamp - it would come on for 5 seconds then go out. I looked at the DM board, but the capacitors looked good. I did notice that two capacitors (3300uf 10V) were bulding on top. I replaced them and to my complete surprise, the TV worked perfectly again. I used Techman's suggestion on looking at the boards, but the diagrams and pictures weren't accurate. I just used my intuition and took it apart making sure I marked all the wires ( a ton of them!) appropriately. If you are mechanically inclined, it takes some patience, but isn't that difficult. It cost me $12.00 to fix, plus buying the solder and de-soldering guns. Good Luck.
Posted on Oct 02, 2007
    Genius:
  • 1,153 Answers
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 Hope this helps!
Posted on Aug 22, 2007
My tv went off an red light is blinkin
The red light indicates that the lamp has failed to light. You need a new lamp or the capacitors on PWB-Power need to be replaced. Try getting a new lamp first.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Red "lamp" light stays on
Red light indicates the lamp has failed to light. You may just need to buy a new lamp. If that does not help then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv starts to turn on then red light comes on and tv turns off
The red light indicates the lamp has has failed to light. You might just need a new lamp. If replacing the lamp does not solve your problem then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
594 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
