Question about GE Profile JT915 Electric Single Oven
This is an electric convection oven
Stupid question of the day.... I want to roast/cook a brisket roast like I always have -- covered w/ aluminum foil with holes punched in the top. I haven't tried it but want to be sure that I won't mess up the convection part of the oven. I've never used convection cooking and have read and reread the owners man. but no where does it say it is ok to use al. foil when cooking on regular "cook" not convection. Am I making this too hard; can I do this?
  • sammychips Aug 21, 2007
    Got it!!! Thanks.
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
Posted on Dec 29, 2007
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
F1 error code and beeps
My name is Peter. I am a retired field service appliance technician.
You need to proved me with the oven model number. This number is located on a metal plate, on the top front after you open the door.
The general code F1 indicates a communication problem within your control system.
The code F1 is different depending on the manufacture and model number.
Mar 17, 2015 | Ovens
F1 error
Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Feb 16, 2010 | GE Monogram® ZET1038 Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    Nov 26, 2009 | Viking Ovens
    Ge profile oven/convection oven humming when on convection settin
    ensure that your convection fan is turning
    a hum on this model usualy means that the convection motor can seize up a bit
    sometimes all you need to do is redjust the fan blade
    Oct 13, 2009 | Ovens
    Oven does not heat
    I would suggest that you check the oven element, it sounds as though it is faulty to me.
    Dec 14, 2008 | Ovens
    Never used Convection JTP 5650DI55
    Did you try going to the GE website? If not, try it:
    When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
    If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
    Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
    Convection fan not working
    Check for a bad fan motor or a jammed blade.
    Jan 01, 2007 | GE Profile JK915 Electric Single Oven
    GE Profile JT915 Electric Single Oven Logo
    326 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
