Question about IBM ThinkPad T21 Notebook
Laptop won't boot
When I try to start my IBM T21, I get nothing but a millisecond green light on my hard drive icon on the keyboard. I've tried with and without a battery, and have tried a different DIMM. Could this be my CMOS or maybe the MB gone bad (the battery does charge)? Thank you...
  • 78 Answers
This could be an indicator of one of two things: 1. Bad motherboard 2. Short circuit. If you can, disconnect the CD-Rom drive, hard-drive AND the keyboard if possible. If you turn the laptop upside down you can normally see the screws relating to each of these components. Do one at a time and test to eliminate them. M
Posted on Aug 21, 2007
  • Brykx Sep 06, 2010
    Try to hold the "Fn" key then press the power button
Sony vaio notebook won't switch on
Can you see any display from the screen? if its a new hard drive, with no Operating System the it show anything at all, try to insert a boot cd and boot from the cd
Oct 22, 2012 | Computers & Internet
Need info about series
The type of drive is IDE and 2.5- Inch for all those models.
T20, T21, T22, T23 --- 2647 all use the same IDE type of drive.
These you can buy for example in ebay. Search for laptop hdd ide 2.5inch or similar.
Jul 01, 2012 | IBM ThinkPad T40 2373 Notebook
T21 thinkpad will not open when it is turned on only the ibm screen appears all lights light up but then the hard drive light goes out bios or startup options will not work
check in bios is your hard drive visible and check boot options. If hard drive is visible try to install operating system.
Apr 14, 2010 | HP zv5160US Notebook
IBM -t21 does not boot (all the time)
I am wondering about the environment in which you normally use this unit, which is heat sensitive, and
which, after it cools off a bit will work as you say after it is allowed to dissipate heat after use.
Make sure the space in which it used is not overheated and preferably air-conditioned. Try to maintain
room temperature of 68 degrees Fahrenheit or lower down to a minimum of 40 degrees.
Apr 11, 2009 | IBM ThinkPad T20 2647 Notebook
How large of a hard drive is supported on the ibm t21
The ThinkPad T21 is a laptop with a single drive bay.
You cannot setup this laptop with two hard drives in any RAID configuration.
You can add an external USB hard drive and copy/backup data to this hard drive.
OR
You can connect this laptop to a network and copy/backup data to another computer/server on the network.
Mar 16, 2009 | IBM ThinkPad T21 2647 Notebook
IBM thinkpad T21 overheating?
Does the battery get very hot? If so try running the laptop with it removed! This problem might also caused by a faulty heat sensor on the motherboard. Given the current cost of new laptops I wouldn't spend a lot of money on any repair options, but you could invest in a "laptop cooler" or chill mat see this link
http://www.quadcooler.com/
Aug 19, 2008 | IBM ThinkPad T21 Notebook
IBM T21 doesn't start
try to start it with the battery out by pluging it straight, the battery is dead and its causing problems
Mar 13, 2008 | IBM ThinkPad T21 2647 Notebook
Nothing appear on the screen
Remove any devices connected and power it on by itslef, either on battery or power source, if it doesnt work, it may have bad processor, When they go bad most laptops wont boot period.
Feb 18, 2008 | IBM ThinkPad T21 Notebook
IBM T21
i have the same problem. actually its a common problem for many T21 and other old IBM laptops.
i searched that you have to take all power (batery, adaptor)
press the power 10 times and press it for 30 secs then reinsert the battery or adaptor and try to power it on.
they say its done to discharge a certain capacitor that got overcharged after overcharging the battery.
that worked for me before but now my T21 wont start any more with this process.
May 20, 2007 | IBM ThinkPad T21 Notebook
IBM T 42 - Not starting
If the laptop is not even getting to boot the hard drive, then their may be a problem some where on the motherboard and it may need to be replaced. Before replacing the motherboard, there are a few things you can try. 1) If you have extra memory, try swapping in new memory and see if the laptop boots then. 2) Try disconnecting all peripherals and add-ons and see if the laptop boots then.
Oct 15, 2006 | IBM ThinkPad T42 Notebook
IBM ThinkPad T21 Notebook Logo
151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
