Cover is open, will not close with new tape in. Reattached the power souce flashes also
SOURCE: Door Jam
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: i have a camera sony dcr-hc51e, (c:32:11 problem)
actually 32:11 is related to the casette compartment error.
reset the camcorder.
if the problem perist then you had to go to the service centre as mechnical section of the camcorder is not working properly and u cant align that your own.
thanx
jasdeep
SOURCE: my sony handycam dcr-hc26 door won't close
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
exactly same problem DCR-HC26
I am receiving an error c:32:11 and my Lcd is blue when swicted to camera mode
We have a DCR HC30, which is about three years old. Recently, after recording on the tape, we took out the tape and put in a new one. The tape won't go back in and the cover will not close. The error code C:32:11 flashes and suggests to reattach the power source. Several attempts with this solution have not produced any results.
and i too, have the same f*&'n problem! can anyone PLEASE make a suggestion!!!???!!!!
