Question about Acer Aspire5100 Notebook
Sound crackles the sound crackles every 10-12 seconds no matter what im doing. it does it when i am playing the xm radio on their website, when im using itunes and playing a dvd. it doesnt do it however when i am using the music on myspace. (myspace is stupid btw) i have unistalled and re-installed the sound driver but it didnt work. i also did a system restore and that didnt work either. any help is appreciated
  • gooberhead Aug 21, 2007
    it still does it even with the headphones. ill just have to give Acer a call about it
    it still does it. ill just ahve to give acer a call
  • 78 Answers
Try connecting a set of headphones to the audio plug on the laptop. See if the sounds are still there. This might be a problem with your speakers, either they are faulty or they are picking up interference. M
Posted on Aug 21, 2007
  • Austin Walters
    Austin Walters Aug 21, 2007
    Sometimes, too many running applications or a spyware infection could cause high CPU usage and affect the audio.
    If you dont suspect any of the above then I would agree and ring Acer if it is still under warranty.
    Thanks
    Moncapitaan
Skydock won't play iTunes through the radio like it does for the satellite radio. The song plays but no sound comes from anything other than the XM Skydock App.
hi donald!
it seems like you haven't properly installed the sky dock yet.
can you tell me the model of the sky dock you purchased?
Mar 30, 2011 | SIRIUS XM Radio XM SkyDock
How do I get to radio tune
Turn XM Roady2 'on' using the POWER switch. Go to MENU and go the FM Frequency. Select your frequency of an empty channel in your area, then turn off the Roady2 using the POWER switch. Do NOT do this by turning the car on and off as it tends not to save any settings when you do that. Always use the POWER button. Also, the website 'Radio-Locator' has a utility that will help you find an EMPTY FM channel in your are for your XM radio to use! Good luck and let me know how it works out for you- okay?
Jun 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
Aug 05, 2009 | Delphi SKYFi2 SA10126 XM Radio Receiver
RADIO RECEIVES A SIGNAL. DISPLAYS SHOWS CHANNELS,
No not the radio...i thing the ear hones are malfunctioning
Jun 07, 2009 | Delphi Roady XT XM Radio Receiver
05' Accord Radio volume
the tuner section in the car radio is dying.  It may be time for that XM radio you want.  Buy the easy install kit on ebay.
Apr 01, 2009 | 2005 Honda Accord
I have XM radio hooked to cassette player adapter in my car. The new adapter keeps sounding like it is rewinding. XM plays for 30 seconds and then ''rewinds'' again, over and over.
Unfortunately your tape play has the auto reverse feature. It is detecting that the tape is not turning via a reel counter. Sensing no movement ( as you have an audio adaptor inserted rather than a real tape) it is trying to switch to the other side of the tape.
Not very much you can do.
You could purchase an FM modulator and basically re-transmit the Xm over an un-used frequency on the FM band to slve your problem
Mar 12, 2009 | RCA Audio Players & Recorders
Crackling Speakers
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
melnavz
Feb 10, 2009 | HP Computers & Internet
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Acer Aspire5100 Notebook Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
