Question about Emerson PD6810 CD Boombox
Emerson PD6810 CD Boombox Error
My CD player works just fine and then stops playing with the letters "ER" on the display. This happens 2 or 3 times a day with any CD. When I get the error I remove the CD, put the CD back in and hit play and the player will work for another couple hours without any problems.
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Posted on Feb 24, 2008
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Oct 08, 2018 | Sylvania Audio Players & Recorders
I bought a used Emerson PD6810 Portable. It plays great but it won't play with batteries and I tested the batteries they are good. Any advice?
check for a switch at the back or pull the power lead out of the jack socket as some machines will not operate batteries and power at the same time
Oct 22, 2014 | Emerson PD6810 Portable CD Boom Box...
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
Aux inputs
I found the manual I don't see what to do either
http://audio.manualsonline.com/manuals/mfg/emerson/pd6810.html?idRes=7373492
Oct 22, 2013 | Emerson PD6810 CD Boombox
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
CD PLAYER NOT WORKING
1. make sure you have the cord/batteries inserted the right way.
2. make sure that you have the power to the cd. which is slide the button to the cd, or put the button where the cd is..
3. open the cd
4. place the cd in with the label up
5. close the cd
6. on the front you should see the tracks that it has
7. if it does, just hit play and you should be able to hear the disk moving
let me know if this helps.
Oct 25, 2008 | Emerson PD6810 CD Boombox
Built in Car CD player
get yourself a cd cleaner and clean the cd. then try another cd. if this does not work and if under the warranty take to the shop.
Oct 24, 2008 | Emerson PD6810 CD Boombox
Emerson PD6810 CD Boombox Logo
370 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
