Question about Motorola Mobility RAZR V3
Deleting information i am going to give my razor to someone else now can i delete all of my inforation from the phone but still keep it on my sim
Here's a link for instructions on how to erase all of your information from the phone (from any phone, actually). http://wirelessrecycling.com/home/data_eraser Make sure you've saved all of your information, first.
Posted on Aug 21, 2007
SOURCE:
How do I clear all personal data, before returning the phone?
Many Mobile Telephones give an option to record personal numbers etc. into the phone memory or onto the SIM card. The SIM card often has more memory and this should be the chosen option. If you remove your SIM you should be able to access the telephone memory and see what is in it. Delete all the personal information, there should not be much on it. If you find that all your personal data is saved to the telephone, you should be able to save the information to the SIM, then remove the SIM and delete the data on the phone. If you are keeping the same number and same SIM, then your personal data will be available on your new phone. If you are changing your service provider and getting a new phone, by putting your old SIM into the new phone you can transfer the SIM data to the new phone and then onto the new SIM. After you should destroy the old SIM by cutting it up through the Electronic Chip. If you have to send it back send it in pieces.
The more modern android type phone will have an option to connect with a PC to recover your data. Alternatively, you might be able to email the data to yourself. After which you will need to either delete all personal stuff if you don't have a memory card in the phone. If you have a memory card just remove it and install it into your new phone, all your data should be there.
Bob.
Jan 09, 2016 | Samsung SCH-I545 Galaxy S4 16GB Verizon...
How do I delete my messages off my sim card all at the same time instead of one at a time?
You don't specify which model of phone you have, so it's hard to help you.
Some phones have an option to clear/empty the incoming box before you enter the inbox, some other have a menu options for a given message, like REPLY, FORWARD, DELETE, QUOTE, DELETE ALL etc.
You have to check patiently, most phones offer this option.
You can also put the phone make and model in the comment box below, so someone can give you more precise instructions for your specific phone.
Nov 20, 2014 | Cell Phones
How to delete apple id
Try going to Apple.com and inputting your old email, it will give you the option to click "forgotten password" and you can go through the security questions to reset your password.
Aug 13, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My nokia Mobil model is 7230. i cannot delete my call list .while deleting invalid selection wil be the answer. if possible plz give some idea
Hope you had changed your SIM card. Most of the latest hand-set can't deleted It can't be deleted just keep for few days It'll be deleted after some few days when your out going call or incoming call increases.
Thanks for using FixYa All the Best!
Aug 08, 2011 | Nokia 7230 Cell Phone
Reading Deleted Messages
No it can't please rate this solution...
Jun 06, 2010 | Motorola Mobility RAZR V3c Cellular Phone
When i receive a call from my contacts on my e66, it just says call on it. ive deleted any duplicates and copied it from memory card and deleted the numbers from the phone and sim can someone help
Please check and ensure that your contacts have the country code attached to the beginning of their cell number(s).
E.g NZVF (+64) 21XXXXXX or
(0064) 21XXXXXXX and not 021XXXXXXX
Keep me informed with your progress.
Jun 04, 2009 | Nokia E66 Smartphone
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Getting rid of phone #'s and text on motorola razor v3
All of your texts and numbers should all be on the SIM card itself and not the phone.
So you can give the phone itself to a friend but keep the sim.
Hope this helped.
Dec 17, 2008 | Motorola Mobility RAZR V3
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Motorola Razor Phone
First,go to setting,initial set up, master reset,this will delete all your inbox/oubox,or restore to original phone setting..hope it will help...
Nov 18, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
