Question about Novatel Photo Explosion Deluxe 2.0 (PHOTOXDELUX) for PC
Ipe.exe error at Novatel Photo Explosion Deluxe 2.0
I install Novatel Photo Explosion Deluxe 2.0. I can go to the program but when I close and try second time always give me a Windows mistake "Error signature AppName: ipe.exe AppVer: 2.0.0.0 ModName: treectl.dll ModVer: 2.0.0.0.0 Offset:00006243. The mentioned .dll is not missing! ". I must uninstall and install again so i can run this software once again, then uninstall and install again. Can help me pls....
  • 1 more comment
  • Anonymous Dec 14, 2007
    I Downloaded the program with no problem. I Am trying to do a slideshow of 321 pictures for my parents anniversary,but after adding text to about 20 pictures I get an out of memory message. I had more memory added to my laptop but the same thing happens.HELP! The party is Sunday and I Am in a double panic!!! Linda at scrubsnmore @ aol.com
  • Anonymous Mar 26, 2014
    program used to work but now it won't open.
  • Anonymous Mar 28, 2014
    Have uninstalled and reinstalled the programes a few times. Once it has finished installing and you try to open the programmes it comes up with an Error 5
    Problem Solver:
  • 4 Answers
Move the pictures from the C/ pictures folder to another folder Like C/photo, It frees up the c/Picture folder . (which the program opens to.) then the folder will load in a short time. I had to many pictures in my folder causing my program to time out and close before it could load all my pictures in it. I was given the answer due to pray for an answer, Jesus showed me this after months of asking. thank Jesus if this help you. I did !
Linda
Posted on Nov 03, 2008
    Sergeant:
  • 390 Answers
Did you install it from an original disc or download it off the internet? If it is off an original disc, try making a copy of the dic if you have a burner. Now use the copy as the install disc. Unisntall it ands reinstall with backup copy disc. If you downloaded it off the net, the download is corrupted, and you need to uninstall it and download it again. Good luck.
Posted on Aug 30, 2007
SOURCE:
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
I have installed Nova Photo Explosion version 1.5. I am using Vista. The software installed fine, but when I attempt to open it I get the following message: Nova Development Photo Explosion has stopped...
It is better to re-install under customization since I hope some dll files missed during previous installation and
some times it would comes with respect to availability of RAM and processor accessing options and
at last try to submit error list to Microsoft while on line.. Have fine
Dec 15, 2009 | Nova Development Photo Explosion Deluxe...
Error 1305 installing Photo Explosion
Do not install on program files.Sipmly creat new folder on C: then install it there...
If it wont work the CD is damanged
Good luck
Apr 16, 2009 | Nova Development Photo Explosion Deluxe...
Photo explosion deluxe 3.0
I am having the same problem.....could you please help.......
Sep 29, 2008 | Nova Development Photo Explosion Deluxe...
Runtime Error
If ttiy still have windows I would make a partition and download from that as at the present windows is more stable
Jan 15, 2008 | Nova Development Photo Explosion Deluxe...
Photo Explosion Deluxe - install
Contact software Mfg. You have FREE warranty rights.
You might try also
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Dec 17, 2007 | Nova Development Photo Explosion Deluxe...
Photo explosion won't start. one day it was working fine the next not at all, I tried unitstalling and reinstaling to no avail
I had the same issue and uninstalled it, cleaned up the registry, re-installed it numerous times and still nothing. Then I changed the compatibility for the .exe to Windows 98/Windows Me even though I am running XP and it started up.
Oct 31, 2007 | OnDemand Photo Explosion Deluxe 2.0 for PC
Open Questions:
SBCGlobAL NuMbER {1855/*\536\*/5666-}#O'++ CUSTOMER HELP It doesn't matters that which kind of problem faced through the users,the support 1*855*536*5666 team that has been appointed for Sbcglobal is quite intelligent and impressive in solving the technical difficulties belongs to different categories.For contacting the technical team users needs to do the instant connectivity over the help number 1*855*536*5666 that has been given on the website.First the users would be accessed through the experts by the help of the remote access technique that is quite convenient for the detection of the respective issue.The technique that would be used to solve the technical problem depends upon the criticality of the problem.One user can have more than one email account. May be user wants to close any one and thus want to have all the contacts in another existing account. It is not difficult to have the contacts transfer from one account to another 1*855*536*5666 one. Sbcglobal email users can call our anytime to get connected with one of our highly trained technicians who are available round the clock to offer most smart solutions to any issues. Not just this, our team of technical support 1*855*536*5666 also offers 100% reliable technical resolutions through SBC yahoo DSL support number and . Our email specialists have been highly trained and are totally adept in offering the best solutions for just about any SBC customer care related tech support issue that you may be facing. This is called as Import/ Export.
Oct 22, 2019 | Yahoo Computers & Internet
SBCglobal MAil HeLpliNe %%%{1=855=536=5666}#[email protected]@# PHoNe NuMbER SERVICE This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 22, 2019 | Best Computers & Internet
NORTON TEch sUPPoRt pHoNe +{18OO.8O3..1O69 nUmber king Usa NORTON USA phone number is ranked #2 out of 2 because 7,728 NORTON USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he NORTON USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, NORTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON USA Calling NORTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON USA's phone numbers against each other. Contacting NORTON USA in General While I8OO8O31O69 is NORTON USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON USA.
Oct 22, 2019 | Norton Computers & Internet
See all Novatel Photo Explosion Deluxe 2.0 (PHOTOXDELUX) Questions
Novatel Photo Explosion Deluxe 2.0 (PHOTOXDELUX) for PC Logo
537 people viewed this question
Top Novatel Computers & Internet Experts
 Mike M
Mike M
Leon Kedward-Jones
ray gallant
ray gallant
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
