Question about Teac DUAL CASSETTE A/R 110/220 Single Dual Cassette Deck
Deck turns on but doesn't do anything else. Motor runs.
Actually, it's only a single cassette and I'm not sure of the model; got it for a couple of $ with the assurance it had been tested - perhaps it was, but not with a cassette to see if it turned. I've opened it up and the main drive belt is broken (or just disconnected - it's kind of a sticky rubber that gloms onto itself). It's a flat belt about .25 in. wide. There's a kind of flywheel about 1.5 in. in diameter that seems to drive the other belts (which both look like "O" rings) - does the main belt go from the motor around the flywheel or does it drive something else? When I tried putting it around the flywheel, the motor seemed to stall, as though the flywheel was stuck or the motor just didn't have the power to turn it. Should the motor spin the flywheel even when the play/FF/Rew buttons are not engaged? Also, how loose should the other belts be, the "O" ring looking ones? They seem very sloppy to me, not at all like a car fan belt, and seem very stretchy. Thanks for your help. John
The main flat belt you describe is probably the capstan belt. The "flywheel" you describe drives the capstan. I don't know the model number of your deck (it would help if you could say what it is), but I'm pretty sure that the flat belt should go around the big flywheel and then around a motor pulley that should be very close to the flywheel. The motor should spin the flywheel even if the play/FF/RW buttons are not engaged. This might sound funny, but the other "O" ring belts might be very important (control motor belts) or not that important at all (tape counter belts)--it depends on the model number of the deck. One more thing: Every healthy capstan belt I've ever seen is NOT sticky and does NOT glom onto itself. That belt sounds like it is very old and needs to be replaced.
Posted on Oct 06, 2007
SOURCE:
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony dual deck, deck B works fine, deck A won' run the tape but just keeps clicking as it auto-reverses.
Hi amitchell47,
The rubber belts that turns the gears is already worn out. Usually, there are two rubber belts in a cassette deck. You have to replace both belts. I hope everything works out. Good luck.
Jul 25, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
243 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
