Question about Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Video/Audio disappears every 30 secs or so but power on TV remains on.
  • 2 more comments
  • Anonymous Nov 18, 2007
    I turn on the tv and the power light comes on and the screen comes up along with the sound and then allof a sudden it shuts off the sound and the picture,but the power light stays on,in about 15-30 comes back on,that is the picture and the sound.Then it breaks down again and again.
  • Anonymous Nov 25, 2007
    Have the same problem sound and picture goes off and on
    I have Sony KDF - E60A20 60 Inch HDTV LCD Television Please tell me what the solution could be to repair. Thank you.
    Newell Warren
    E-mail Address
  • ladyj3636 Apr 05, 2009
    I have the exact same problem! We have cleaned around the lamp and all. I lose sound and video but the green power light stays on. It will do this for appx. 40-55 minutes and then stay on.
  • maniacjugalo Apr 28, 2009
    id had the same as above, and solution 2 was exactly what i needed to do. thank you for the time to post your advice!
    Problem Solver:
  • 11 Answers
It works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
  • 1,153 Answers
You say disappears, could this be with a loud noise and then no video, and is it like cable being cut off, if so it sounds like tuner problems. Which at one time Sony had alot of.
Posted on Aug 22, 2007
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ... > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
While tv is on, at times screen just blacks out ...then comes on remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Tv stays keeps going black every 3 seconds. still has power but no sound then comes bac on.
If this is a KDF-E60A20, most likely you have a bad Lamp. It is a common symptom.
I hope this helps,
Nov 02, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony blink red 5 times and video or audio. It happen all of a sudden...what could be the problem?
5 is a bad lamp ballast . but you should check the lamp first. those tv's don't always detect ballast trying to start the lamp correctly. especially if its even been repaired before . most service poeple dont put the hv detect wire back in the correct place so when the lamp goes bad the tv thinks the ballast is bad. listen for a little short buzz or crackle noise from the back of the tv when you try to turn it on . the buzz noise last about 1 second and should happen about every 30 secoinds 3 times . if you hear it only the lamp is probly bad. or its a bad ballast
Oct 04, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20, picture and sound go out then re-appear every 30 sec
Was it just the bulb or the complete lamp assembly? If it was just the bulb you need to handle it with latex gloves to avoid getting oils from your hands onto the lamp.
Sep 10, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Kdf- e60a20
I may be late with this but it souonds once again ike dust in and on the bulb cage. These TV's will turn off by themselves if they over heat. The extra dust(not much) can/will cause the TV to heat up and shutdown for a few seconds to a minute. Depending on the time of year and location of the TV can vary.
Try removing the bulb and cleaning it with compressed air and a micr fiber towel. Of course don't touch the blub itself as the skin oils will cause it to break.
Jun 20, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have this sony kdf-e60a20
lamp is monitored by an over-current protect circuit. When the lamp starts drawing a little more current than normal, the set starts shutting off the video and audio then in a couple minutes restrike the lamp. Unique to sony WEGA's, replace w/ new type xl-2200u, you should be o.k.
May 03, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
259 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
