Question about Samsung Digimax S500 Digital Camera
Camera will not stay on
When I turn my camera on it brings up the greating screen beeps 3 times then shuts off. Once in a while it will turn on longer and constantly beep and show across screen low battery
    Sergeant:
  • 274 Answers
Battery is dead. Replace them. Check the settings in the menu and if you are using rechargeables make sure the settings are correct. Off the shelf should be set as Alkaline. ****I have the same model camera
Posted on Sep 24, 2007
SOURCE:
When i try to turn my camera on it beeps 3 times and shuts off.
It must be the end of the Samsungl camera battery life made this matter ,why not change the Samsung digital camera battery for a try.It is a simple but usual problem.
Jun 02, 2010 | Samsung S860 Digital Camera
Turn on the power and the camera beeps 3 times?
hmmm... accesses the card ok? 3 beeps on a computer is a memory thing... might try a differnt SD card... Otherwise, probably is trash, cameras are so cheap that having a shop repair them is just not worth it.
Peace,
Mar 28, 2010 | Samsung S85 Digital Camera
I click the on button on polaroid i834 digital camera, then stops
Sounds like the battery is too low. Replace/recharge batteries.
Oct 03, 2009 | Polaroid i834 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Polaroid i735 digital camera troubleshooting
the same thing happens to my camera. did u ever end up fixing it
Jun 02, 2008 | Polaroid I533P Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
