Question about Kenmore 17024 Built-in Dishwasher
Its a kenmore 665.17032403
The dishwasher is not cleaning the upper level correctly. Door slime is left when opening the door. A repair man came out and cleaned some food out of it last year and I cant remember where he opened it up to get it. I took the arm and the tube out to make sure not food was caught in the tube that feeds the upper spray arm.it all looks clean.I am wondering if I need to get a alan wrench and open up the motor or what. Thanks
  • tmack Sep 02, 2007
    yep. take the bottom blade off the dishwasher and make sure no food is in the tube that feeds the top. take the top of the food grinder off and clean the food out of it. It is like 3or 4 alan fittings. runn a half gallon of white vinager through it and its good as new....
665.17032 403
Plastic over one of the control buttons has started to peal off control panel. Is there is replacment cover or replace the entire control unit?
Posted on Aug 23, 2008
Beko de2542f dishwasher
If you live in Rancho Cordova, CA and need dishwasher repair service call us at 916 823 3070 or visit our website Dishwasher Repair Rancho Cordova 916 823 3070 GE Maytag Ken
Sep 03, 2017 | Beko Dishwashers
Detergent not dissolving therefore some items not clean.
Jerry had two good First Checks with the water level and the temperature. Turn on the dishwasher and open the door after it completes filling and check the level and temperature.
A third possibility if the level and temperature are correct is that your dishwasher is not spraying enough water around. This could be due to a faulty pump, but more often I see a reduced spray from a clogged filter on the input to the pump.
You can check the amount of spray by waiting until it starts the wash cycle and open the door quickly. Water should be pouring off the upper rack and you should either have water come out of the door or have it be very close to spraying out.
Some dishwasher models have an easily accessible filter, others take some tools to get down to it.
Mar 31, 2015 | Hotpoint Dishwashers
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
The upper shelf of my 17379 dishwasher is not getting water.
check your float switch. Open the door and look on the left or right side, It may look juke a small dome pull that out and clean it. Food particals get stuck on the stem and starts the motor befor it get enough water in the machine to clean the dishes and make enough pressure to get to the top shelf
Apr 21, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Buzzing in upper left hand corner of door on Asko D1776. When door is fully open it stops but when door is up it continues and you can feel warmth in the uopper left hand corner.
I think what you are describing is the "turbo fan" assembly. This device is used to remove the condensation to insure dishes are dry at the end of a cycle. It actually vent`s out the bottom left side via a plastic housing but the vent motor assembly is located inside the door at the upper left corner.
If it ( the fan) continues to run or "hums" because it`s trying to run, even when the dishwasher is idle or no program has been selected, it is likely a problem within` the control board unfortunately. This is usually caused by the vent assembly getting clogged up so it cannot open correctly and the "wax motor" ( the small device which open`s and closes the vent ) burns up and short`s out the control board.
If you`re capable, you can visually inspect the control and look for burnt up path ways on the printed circuit side ( green side with lot`s of solder joints ).
If so you`ll need to replace the control as well as the fan assembly, or clean the assembly really well as most asko control`s come with a new "wax motor"...or used to where I live. Unfortunately those control`s retail for about $400 and up, and most now are of the "rebuilt/refurbished" kind. The part number should be ( if the model number is correct ) # 8801201.
Hope this help`s move you forward. Let me know either way and I`ll try to assist you further.
Thank`s for visiting "fixya" today for your repair solution`s and good luck moving forward.
macmarkus :)
Mar 19, 2010 | Asko D1776 Stainless Steel Built-in...
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
Where do I find the serial number for the Kenmore Ultra wash III dishwasher
Look at following areas for the model number
* On Right Hand Side Of Upper
* Front Tub Or Door Jam
* On Flange Behind Dishwasher Door
* Behind Latch Strike
* Upper Left Corner Of Frame
Jul 19, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore elite dishwasher 665 water won't drain
Mine's doing the same thing, would love to know if you found a solution
Jun 19, 2009 | Kenmore Dishwashers
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Kenmore 17024 Built-in Dishwasher Logo
549 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
