Question about E-Machines M2000S 15.4" LCD Monitor
Monitor to tower compatibility.
I just bought a 15" e-machines LCD monitor, and I'm not sure what I need to hook it up to my tower. The Monitor cable has 3 rows of 5 pins, and my tower only seems to have slots for two rows of 5 pins.....I went to Best Buy and Radio Shack, and neither of them seem to have any clue what I'm talking about.
  • 1 more comment
  • Squeakity Aug 21, 2007
    Sort of like that - the shape of the pins is kind of rhomboid, though, and there's only 5 pins across....although I'm fairly certain that the monitor says "VGA" on that part....
    That's it exactly. I guess the one with only two rows is DVI?
    Sorry - I don't remember clearly the connectors on the tower - just that it was 2 rows, but not how many pins were part of each....
Could the connecter with 2 rows be a DB9? Does it look like this? If not, can you describe in detail what it looks like?
Posted on Aug 21, 2007
  • 78 Answers
It sounds like you have a DVI cable on your monitor. (See attached picture) If you go into radioshack ask them for a DVI to VGA connector. http://www.amazon.co.uk/2m-DVI-TO-VGA-CABLE/dp/B000K5O1M8 Let me know if the picture looks like the cable you have on your monitor. M
  • Austin Walters
    Austin Walters Aug 21, 2007
    Can you do a search on Google images for "vga Connector" and let me know if you see a picture that is the same as your monitor.
    Or are you able to take a picture and email it to me?
    M
  • Austin Walters
    It looks like you have a DVI Video Card.
    If you go to radio shack and ask them for this:
    http://www.radioshack.com/sm-belkin-f2e4...
    You have VGA monitor connector and you have a DVI video card.
4 Suggested Answers
  • 4 Answers
SOURCE: Black Screen-No picture
Normally when an LCD monitor goes black, it is because the inverter goes out (which essentially is the backlighting).  To verify this problem, hold a flashlight up to the monitor while it is turned on and see if you can "see" the picture.  If this is the case, it could be repaired, but realistically, the cost to replace it might be cheaper (and you would probably end up with a larger monitor to boot).
Posted on Jan 01, 2008
  • 5 Answers
SOURCE: Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Posted on Jun 10, 2009
eng_darwish1
  • 233 Answers
SOURCE: My Sister has a dell monitor and a emachines
try setting the display settings to 800x600 and frequency (refresh rate 60 hrz)
Posted on Feb 23, 2010
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
Hooked up New Hp comp (tower only) to slightly new HP2007 monitor but there is no sound.Could you give me an idea of what I missed?
Make sure the audio cable supplied with the monitor is connected correctly. Make sure it is connected to the green (speaker out) jack at the back of tower and the same green (audio in) jack on the monitor. Also make sure the volume on both your PC and monitor is turned up and not muted
Dec 03, 2010 | HP W2007 LCD Monitor
My Sister has a dell monitor and a emachines tower, She cant get the monitor to turn on. is it compatible? Or is there something else she should try cause she has it hooked up right.
They are compatible, make sure your connectors are right... If the emachine is using a graphics card, make sure it is hooked up to the greaphics card not the motherboard but if you do have it hooked up to the graphics card, then try the motherboard's video output.
Feb 23, 2010 | E-Machines eMachines Monitor E15T4
Will not power on... i have two of these monitors that experienced the same problem within 2 weeks of each other
Chances are that you have some problem with the power supply part of your computer. Depends on how your monitor is connected. If it is from the cabinet (tower) then, we need to check for spikes from the machine (chances of getting spikes from SMPS of tower is low). If it is directly connected ensure that the socket has proper stabilized power supply. Let me know how your machine is structured in terms of connection.
Aug 31, 2009 | Sys Technology SYS 15-C-NX (Chrome) 15 in....
PowerBook G4 15" Alumium LCD Cracked, see lines, HELP!!!
the new LCD is not match to your notebook. i'm sure not same all pin outs and pin in. its not compatible to the circuit board of notebook. even the LCD connector is also not compatible.
May 30, 2009 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Flashing Screen
These games are so advanced that at times some of the issues that you encounter the problem lies with the particular machine you have, or the graphics card, or software installed. Remember these games are not tested on all systems. They are just tested on compatible systems granted you have something that runs on a similar OS and compatable machine. These games are tested in a closed environment on a certain type of machine. Trust me the machines they use are worth more than we are willing to spend! Sorry
Oct 09, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
831 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
