Question about Microwave Ovens
Where is the bulb located on Russell Hobbs rhm2018
I have just done this myself on the same microwave - I know this was posted a year ago but maybe you still have it. Unplug the microwave. Remove the cover by unscrewing the screws on the rear and side. As you're facing the microwave, to the front right hand side on the top there's a black oval-ish shaped thing held in place by two metal clips (pictured). This is the light bulb. The clips easily lift up by hand, then you can gently lift out the bulb. With mine it turned out that the bulb wasn't broken it just hadn't been screwed in properly!Where is the bulb located on Russell Hobbs rhm2018 - 8ada370f-1c5e-4600-8102-2c5c0b93f61c.jpg
Posted on Aug 29, 2014
SOURCE:
SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them service@saltoneurope.com. I could not find a manual on their website so I guess you will have to the above #'s wurstdude
Posted on Nov 07, 2008
najah
  • 180 Answers
SOURCE: Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
Posted on May 26, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Posted on Dec 03, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
Posted on Feb 02, 2010
joeguest2
  • 2080 Answers
SOURCE: how to set the clock on my Russell Hobbs microwave RHM2016
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.russellhobbs.co.uk/pdf/product_387_rhm2016_ib.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 8 of the manual for detailed instructions on HOW TO SET THE CLOCK on your microwave. Basically it says to press the CLOCK button, then press the CANCEL button, then enter the current time using the number buttons, then press the CLOCK button again to set it.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Oct 31, 2011
Russell hobbs hob sjs21
Usually you have to remove the jacket from the microwave to reach the release mechanism.
Nov 03, 2017 | Russell Hobbs Microwave Ovens
Have lost instructions for russell hobbs oven/microwave model no RHM20105-H serial no 0133100063
I think this the manual your looking for. That 5 is the model appears to be a S instead. Roll your mouse over the large black rectangle for pop-up download menu.
Russell Hobbs Microwave Oven User Manual ManualsOnline com
Dec 24, 2014 | Russell Hobbs Microwave Ovens
Redeem points - code 22026 Russell Hobbs slow cooker, in Palmerston North
What are you asking??? If you want to redeem points contact the manufacturer.
Sep 19, 2014 | Russell Hobbs Microwave Ovens
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
Russell hobbs cjs28 microwave oven user manual
sir i have a need of owners manual of russel hobbs cjs28 if u have it then plz... send me immediately on this address rehmanmunawar@yahoo.com
Sep 17, 2009 | Microwave Ovens
May 25, 2009 | Microwave Ovens
Microwave Ovens Logo
1,136 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
