2011 Jeep Wrangler Sport Logo
Anonymous Posted on Jun 19, 2013
Engine Check light
I had my rear main seal replaced but they had to remove my transmission and exhaust to do so. Once they completed the job the check engine light will not go away. Any ideas what is causing this and how to remove the check engine light? Thank you Cheers
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Jun 19, 2013
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511674
Points
4903
How to Turn Off The Check Engine Light? If you're performing this procedure in an effort to pass an emissions test when the check engine light or service engine soon light is on or illuminated, read on and in detail to learn how the check engine light reset procedure works. You may have already read information describing how to turn off the check engine light or service engine soon light prior to the emissions test in order to evade the smog inspection. By turning off the check engine or service engine soon light, in actuality deleting all emissions data from your vehicle, the smog machine will not know your vehicle has or has had emissions faults.
This method will NOT work. We will describe the reset or "turn light off" procedure so you may understand the OBDII emissions testing process and how the check engine light or service engine soon light apply to the emissions test.
Perform procedure at your own risk!
Step 1. Locate your vehicle's battery. Disconnect the 12v positive cable (red wire) from battery terminal (+). Leave it disconnect for 5 minutes. While the battery is disconnected, cycle the ignition switch to ON position 3 times.
  • You've just erased important emissions related data which is invaluable to a smog technician attempting to repair your vehicle.
  • You also deleted very important "readiness flag" data which takes days, if not weeks to compile.
Step 2. Insure ignition switch is OFF. Reconnect the battery 12v positive cable (red wire) to battery terminal (+).
  • You're risking electronic component damage. High voltage spark produced during the reconnection of the positive 12v cable can cause damage to fragile electronic emissions component/s.
Step 3. Cycle ignition switch to ON position and wait 1 minute, then start your vehicle. Check Engine Light or Service Engine Soon Light should be reset and turned OFF.
  • If you are successful in turning off the check engine light, this means your vehicle has not stored it's emissions data in the ROM section of it's computer and you have just deleted all data pertaining to your vehicle's engine and emissions systems, probably including your radio & system settings.
Step 4. Drive your vehicle for one week under normal driving conditions. During this period the emissions computer is gathering data and re-learning your vehicle's emissions components and systems. The emissions computer OBDII (on-board diagnostics) system must complete at least one drive cycle (in some cases two or three). A drive cycle is a sequence of internal tests which the emissions computer runs while your vehicle is being driven. This insures all emissions systems are functioning properly. Proper "readiness flags" are set as the computer completes it's cycles. Test cycles are unique to a vehicle. Certain cycles run under very strict parameters, and may require extended driving time to trigger on. Cycle data and readiness flag information is available through your dealership's service department. The data vary widely.
  • During your drive, maybe even as soon as you start the engine, your vehicle realizes an emissions fault, and turns on the Check Engine or Service Engine Soon light.
  • Emissions computer refuses to set a required readiness flag. No check engine light, but no chance of passing the emissions test either. However, you will not know this until your vehicle is smog tested. If the particular emissions test center doesn't offer a free re-test, you forfeit your inspection fee.
Step 5. Take the smog test. Important Note! Your vehicle might not be completely ready for the smog check inspection. Required parameters may have not been set by the emissions computer.
  • Your vehicle might not be ready for the emissions test. There will be no way of knowing this until the smog test is complete. Your normal driving pattern (if not for an extended length of time) may have failed to trigger the emissions computer tests needed to set the required readiness flags.
Passing the Emissions Test - What are my chances of passing the emissions test after resetting the emissions computer and turning off the service engine soon light or check engine light?
A slight chance of passing the emissions test after a reset does exist, but it is very slim. The trick is to get your vehicle smog checked before your engine computer detects the check engine light illuminating trouble code, and only after the required readiness flags have set. The chances of the engine computer setting the required readiness flags before detecting the trouble code and illuminating the check engine light are slim to none. And so our opinion... time is better spent finding a reputable smog check repair station to diagnose the check engine or service engine soon light, then time spent trying to avoid detection and/or repairs.
Even after evading check engine trouble detection, passing the emissions test will require your vehicle's exhaust sample, which will be collected by the smog machine, fall within California Air Resource Board specifications, and all required emissions components be functioning properly. Passing the entire smog test requires your vehicle pass the visual, functional, and emissions portions of the test. One may be able to hide trouble code information by deleting data, but the vehicle's exhaust will not be able to hide high emissions.
Testimonial: "Thank you Brian for that. I am in Australia. Not sure if that all applies to me. But not happy bout this hopefully we can solve the issue. I love this website you boys are just awesome!! :) hahaha Cheers Linda"
Level 3:
  • Jeep Master 19,187 Answers
Jeep Master
Level 3:
Answers
19187
Questions
0
Helped
4341774
Points
82259
Take it to autozone or another place like it and have them read the codes and tell us what they are.
Testimonial: "Thank you for the prompt response. The scary thing is my car is at a mechanics. They have had it for 2 days and they are trying to work it out. I need my car so I am doing my research to solve the problem. "
5 Related Answers
Anonymous
  • 1986 Answers
  • Posted on Oct 07, 2009
SOURCE: wrangler check engine light
If the light was flashing when it came on, then it means your engine is misfiring.
A solid light can mean anything from a loose/faulty gas cap to a transmission issue.
This light comes on when the computer detects a fault of some sort in its diagnostic tests. If it keeps detecting this issue, the light will remain on. If the light turns off, then it has detected that the issue may no longer be present.
In order to find out what the exact reason was for your light, You need to have your car computer scanned to retrieve the code that the computer would have stored when the light triggered. Most garages will do this free of charge. The code will tell you what may have caused the light to initially turn on.
Bob B
  • 272 Answers
  • Posted on May 23, 2009
SOURCE: cost to replace rear main seals on 2001 jeep gr. cher. ltd.
Actually yeah you are in luck that combination only requires dropping the oil pan. The seal is actually fairly easy to do it yourself, if your inclined. Parts about $20.00 and it's book rate is 5 hours. around here shops charge around $85/hour. About $500.00 out the door or under $50.00 if you want to get greasy. Here's a good picture guided step by step on a Jeep CJ with a 4.0 liter, yours is pretty much the same:
http://jeepin.com/features/rearmain/index.asp
Anonymous
  • 35 Answers
  • Posted on Nov 17, 2009
SOURCE: my automatic transmission solenoid is causing
Most transmission solenoids are located within the pan. If you replace the solenoids then it would be a good idea to change out the wiring harness that runs from the main transmission plug to the solenoids. Just lower the pan and drain it. Then, remove the one or two bolts that hold the solenoids in place. Replace the solenoids, wires, transmission filter and fluid at the same time (since you're already there). Make sure that you use a new pan gasket when you put the pan back on or it will leak fluid. Good Luck!
Testimonial: "very helpful"
Anonymous
  • 1985 Answers
  • Posted on Dec 29, 2009
SOURCE: proper way to check transmission fluid
You always check transmission fluid with it running and in park,If your dip stick has a place on it for cold use it cold,Other wise it should be on the full mark,you might want to look under your jeep for any new leaks!
Testimonial: "thanks alot, thats what I thought, no leaks that I can see, I guess they didn't fill it all the way back up"
Anonymous
  • 2926 Answers
  • Posted on Jul 18, 2010
SOURCE: check engine light, vapor canister, have any idea
I would start with the gas cap replacement and see if the issue resolves itself. If you do have a problem with the EVAP (canister) system, it may require tools the average person does not have to help diagnose and correct/repair.
Instrructions on replacing a rear main seal on 2004 kia rio
Oil leaking "in" your valve cover? Where is the oil at/coming from? And, to answar your question, rear main seal is a real job! Requires removing transmission, flex plate/fly wheel! It is the crank shaft seal, on the "rear" of the engine!
How much should it cost to replace rear main seal gmc Yukon xl
transmission has to be pulled to get at the seal, likely a 4 hour job or so plus the seal. Depends on labor rate. Could be extra charges if exhaust bolts are corroded (can't pull trans. with exhaust in)
Have a bad oil leak from back of the motor
Check the rear main seal, if its coming out between engine and transmission it is time to replace. Usually this seal wont stop leaking even with seal conditioner. Depending on engine and chassis either the trans or motor will have to come out in order to replace the seal. If the seal is external than remove the trans, if a 1 piece internal than engine has to come out. Any way you look at it is a time consuming and big job.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Rear seal leaking on 2007 ford escape
In order to replace the rear main seal you will need some auto repair tools and experience . this is a big job , the transmission must be removed to replace this seal, also make sure that the seal is the leak,
oil always flows down, a leak on the top of the engine will flow down and drip at the center rear and look like a rear main seal , make sure that is the leak!!.
Depending on what engine you have and if it has 4 wheel drive the time for a shop to do is from 7 to 10 hours depending on engine size and 4wd,
How to replace rear main oil seal on vx commodore 5.7 auto
To replace the rear main oil seal I would recommend changing the whole rear main plate with gasket seal already done.
1.disconnect battery
2.raise vehicle on hoist
3.remove exhaust
4.remove tail shaft
5.remove starter motor
6.disconnect and remove transmission
7.remove ring gear
8.you will now see rear main assembly.
9.undo bolts holding rear main plate on
10. remove plate and clean surface area,follow these steps in reverse to refit...
1helpful
Check engine light code p1150
Code 1150 for a Lexus means the O2 sensor for bank two sensor one is not working. It could be a problem with the sensor or the wiring harness. Bank two is on the side of the engine with cylinder two, and sensor one is in front of the catalytic converter.
I have a 1983 buick regal limited that is leaking oil from what I believe is the rear main seal. Tomorrow I am going to scoot the transmission back and check to see if there is oil around the flywheel . My...
GM never uses exhaust manifold gaskets, it is a machined fit. The rear main may be two piece in this year, it depends on what engine the car has, you never say, if so you must remove the oil pan. Also if it is a one piece you need the installation tool to install the seal, if you don't do it right it will likely leak even worse.
2helpful
My 1994 camaro w/ 3.4L engine has an oil leak in rear of engine. It is running down both sides of the block in rear. Oil filter is wet, but not leaking, the starter and bell housing drip oil and its...
This is most likely a leak from your rear main seal. It happens and can be a pain to replace if you're a DYI kinda person without the nec. equipment.
  1. Raise and safely support the vehicle with jackstands.
  2. Remove the transmission.
  3. If equipped with a manual transmission, remove the clutch and pressure plate.
  4. Remove the flywheel assembly.
  5. Using a suitable prytool, carefully pry the old seal out.
6. Inspect the crankshaft for nicks or burrs, correct as required.
88143g59.gif Crankshaft rear main seal - 5.7L engine
To install:
  1. Clean the area and coat the seal with engine oil. Install the seal onto tool J-34686 for 3.4L engines, J 41349 for 3.8L engines or J 35621 for 5.7L engines.
  2. Install the tool (with the seal mounted to it) onto the rear of the crankshaft. Tighten the screws snugly to be sure the seal will be installed squarely over the crankshaft.
88143g60.gif Exploded view of the rear main seal installation - 3.4L engine
Click to Enlarge
  1. Tighten the wing nut on the installation tool until it bottoms out.
  2. Remove the tool from the crankshaft or rear oil seal housing, as applicable.
88143g61.gif Rear main seal and installation tool - 3.8L engine
Click to Enlarge
88143g62.gif After position the seal on the tool, install it to the crankshaft housing
  1. Install the flywheel.
  2. If equipped with a manual transmission, install the clutch and pressure plate.
  3. Install the transmission.
  4. Check the fluid levels, start the engine and check for leaks.
Engine Rear Main Seal Leak
neither...rear main seal is broken do to the camshaft rubbing against it. Even fixing it with a new seal it will just leak again..best to just watch the oil lvl and add accordingly.
1helpful
2answers
Main seal
First is it a front seal ,or rear main seal,(front seal,being were you see the pulleys and fan belts,,you have to look at the bottom pulley,follow the shaft to the motor,where the shaft goes into the motor is the front seal,the pulley and everthing behind it has to come out then you pull out the seal,auto zone actually has free tool rental that you can pull the seal,and a tool to put it back in,if a rear main seal its where the shaft from the transmission meets the back of the motor,youll have to pull the trannsmission back,check where you see the oil leek from,the front seal you can do if mechanically inclined,but if its the rear you should take to a mechanic,if this helps please give me a fix ya vote
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
