Gateway M305CRV screen black after XP Pro install attempt
My laptop was working fine. I wanted to install XP Pro. I deleted the partition and started the install. halfway through the install the screen went black . now the computer wont boot up. no fan sound no HD sound. Just a black screen.I tried to connect a external monitor and it is also black screen.
    New Friend:
<strong>Situs Poker Online</strong>
https://yvessaintlaurent.freesite.host/
Posted on Jan 06, 2019
  • 78 Answers
Do you get any lights on the laptop? M
Posted on Aug 21, 2007
SOURCE:
How to format my laptop
Normal 0
To format the hard disk and re-install Windows use the Windows installation CD, and the Windows Product Code on the label at the bottom of your laptop.
Boot up using the Windows installation CD and follow the instructions.
One of the installation early steps, the option to delete the existing partition, then create a new partition and then a full format on this partition (don't do a quick format) and complete the Windows installation.
Next install all of the Toshiba's computer/laptop device drives.
Next install the Windows service packs (SP2 & SP3 for XP, SP1 & SP2 for Vista)
Next Activate Windows via the Internet or by phone.
Next install your programs - Microsoft Office etc.
Next click on Start - Programs - Windows Update (for the latest updates).
Oct 16, 2010 | Toshiba Satellite Pro L300 Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
I reformat my gateway netbook from xp to windows 7 starter... but when I restart it shows an option of windows xp and windows 7. I need to choose windows 7 before the windows start....pls help i dont know...
that happens because you didn't delete your original install of xp. basically you are dual booting operating systems. the best way to recitify this is to reinstall wndows seven and do whats called a destructive install. You should be prompted as to whether or not you want to do an upgrade or a custom install. choose custom and install. this should completely remove xp from the system. if you need any existing data from xp be sure to save it prior.
Dec 09, 2009 | Acer Aspire One Netbook 8.9" Notebook
Installing new OS
If you chose delete partition, ensure that you have saved your data, this will delete all data and format the hard drive to install your new system.
It is the est way to get rid of viruses, bue it will delete everything from hard disk.
If you chose delete partition, chose create new partition afterward, and then format. That is the way it works.
May 11, 2009 | HP Pavilion a1610n PC Desktop
No operating system - instal xp pro
With what you have done, it seems pretty cut and dry. You hard drive appears to be damaged, which is why your having problems formating/accessing it.
I would recommend running a hard drive test. If you not sure how, I would ask a local repair shop to run a quick test on the hard drive to confirm its bad. Most shop will do this test for free, if you get a hard drive through them. If you wanna go online and get your own hard drive, testing should be less than 30 bucks.
If this helps please rate my solution.
May 10, 2009 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Laptop blue screens when trying to reinstall vista
The problem might be with the bad sectors on a hard drive. You should run Scan Disk on a partition where you were trying to install Windows Vista.
Jan 16, 2009 | Dell InspironTM 1501 Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
I want to delete everything and start over!
you'll need to go to SAFE mode, or boot from the install disk, which ever is most accessible.
http://tinyurl.com/6qcpgy
Aug 17, 2008 | Compaq Armada M700 Notebook
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
457 people viewed this question
Ekse
Marvin
Marvin
