Question edited for its proper name.
Question moved from Washing Machines.
Did you measure it?
Ideal brewing temperature is between 195°F and 205°F
Is There a Perfect Coffee Brewing Temperature? According to the National Coffee Association, the ideal water temperature for extraction is between 195°F and 205°F, which is a little below the boiling point of water - 212°F. What's handy about this temperature range is that it works across all brewing methods.
Page 50 of the manual
The adjustment of the economizer for regulating the delivered water temperature is made by the installing service technician.
Question edited for clarity.
Question moved from Cellphones to La Cimbali. If you put 'make model (what it is)' at the beginning, you are more likely to be offered the correct Category.
It is a Professional Espresso Maker Rebecca. It needs professional service. Contact their support direct. The first thing to try is disconnecting from power for 5 minutes.
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
Operators manual only describes how to install and set up. The Technician's manual is translated from Italian and is purposely vague. (Cimbali wants you to go to tech school). Suggest you ask for a annual preventive maintenance from your local service Cimbali dealer. You may need an overhaul/de-scaling which will be very expensive (+$1,000) in labor and parts. (mostly labor as it takes us about 40-50 hours per machine.) Hopefully you just need to change the worn parts in both groups and a vacuum valve. Good luck!
