Question about Kenmore 54501 Dehumidifier
Connector hose inside dehumidifier leaks
We purchased a connector hose from Sears. The connection inside the dehumidifier (not the external connection to the hose that goes to the drain) leaks, so the bucket below fills - not what we want to happen. We can't seem to tighten the connection enough so there is no leakage.
  • 5 more comments
  • Pudge2 Jun 28, 2008
    I have a 25-pint Frigidaire dehumidifier. I can't get a tight fit for the drain hose on the inside connection. The result is that water goes into the bucket rather than out through the drain hose. I've tried several different hose washers, but none help to make a secure connection.
  • Anonymous Jul 16, 2008
    I have the same problem !
  • john96 Aug 18, 2008
    same problem. What is the solution?
  • Anonymous Sep 08, 2008
    Where does the plastic tube hookup to drain directly into a sump pump?
  • drpankajgarg Apr 21, 2009
    water keeps filling in the bucket despite the hose connection.
  • DAVE SULLIVAN Jun 05, 2013
    The problem is that the plastic tube with the hose connection on one end does not have a water-tight fit to the other plastic pipe inside the unit and thus leaks. There should be another or better o-ring. I'm going to try a rubber band and see if that works.
  • Anonymous Mar 31, 2014
    1/4 in drain hose has hole in it. Can't seem to find a way to remove it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Let me know if you still have this
Posted on Dec 19, 2007
SOURCE:
Drain hose connector
Check with a local Sears store. They specialise in Kenmore appliances and can maybe order one for you.
Sep 29, 2013 | Kenmore 54501 Dehumidifier
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Can I connect a hose so the dehumidifier can drain itself
if it has a place to connect a drain hose to there usually inside the pan the connector should have came in the box with the DIRECTIONSSSSSSSSSSSSSSSS
Jun 27, 2011 | Maytag M3DH30B2A Dehumidifier
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
Can a hose be attached to the LG 45 dehumidifier to allow to drain as it fills?
Yes a hose can be connected to this unit.
1. Remove the drain-hole cover from the back of the unit.
2. Connect a garden hose to the threaded hose connector.
3. Push the hose connector tightly to the drain-hole on the back of the unit
This is explained on the manual on page 12. Hope this helps
Jul 29, 2010 | LG DH404E Dehumidifier
My dehumidifier runs over or leaks is there a way to plug into a hose to see if that takes care of the problem
If you purchased the dehumidifier new, it would have come with a part called a connector drain hose. This part is a long plastic tube with threads on one end to accept a hose. The part simply slides into the rear of the machine (with the threads of the part facing the rear). If you dont have the connector drain hose, it's part number is 5214A20027B and you can easily order it online for less than $10.
Jan 18, 2010 | Kenmore 54351 Dehumidifier
Do I need an attachment to connect hose to my new dehumidifier?
it should be generic. you just need a part with the same thread pattern. you could fix that a lot of different ways. as long as it screws in your ok. make sure you put some teflon tape on it to prevent it from dripping
Oct 06, 2009 | Kenmore 54501 Dehumidifier
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Owners manual missing - my problem
you should have a drain hose connector. this connecter is inserted into the back of the dehumidifier. your hose can then be connected to the connecter. if you are also miising your connecter,sears or any store similiar will have one
Jul 18, 2008 | LG DH404E Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
969 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
