Question about Siemens Gigaset 2420 Cordless Phone
Siemens Phone My Siemens 2420 base and gigaset phones are having display problems, I can hardly see the words displayed on screen. As well sometimes the keys are sticking on the key pad. Do you have a solution. Thank you.
  • Anonymous May 23, 2008
    The display was hard to read for about one year, and then it completely went out, and the buttons are making it where you need to push very hard to get them to work, the worst button is the REL button on the bottom.
  • Anonymous Jun 05, 2008
    My desk station display is totally gone. This makes the phone almost totally useless. Is there a battery to make it light up again?
Some dude on ebay a while back specialized in fixing this pblm w a guarantee, i think the price was around $75, a little steep for what the phone is worth. You may want to browse some of the shops that come up in response to searching on "siemens 2420" as I forgot the guy's name...
Posted on Aug 02, 2008
The display on my siemens 2420 is not showing up. Can anyone tell me the steps to set up my answering machine? I need it actually broke down for me, ie: press the menu button 4 times, press select, etc. Since I have no display I have no idea when I need to press "select"
Thank you!
Posted on Jul 26, 2008
    Novelist:
  • 106 Answers
I just replied to a similar post. This is a common problem, not only with the Siemens but most all manufacturers that used this design of display on many different devices. And in this case, the display connections are pressed on with a special machine and can't be replaced by a do it yourselfer. Sorry I can only recommend sending it in for repair.
Posted on Jan 11, 2008
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset A260 cordless phone fail to register
We've tried to register the Siemens A260 handset to the base but it continues to flash "Base".. and does not work.
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
LCD display screen replacement for Siemens 8825 phone base
Yes we have new ones we sell to the do it yourselfers or you can send it in for repair and we do some updating and put in a new display. You can find us by googling Siemens cordless telephone repair and look at the non-sponsored links.
May 30, 2008 | Siemens Gigaset 8825 Cordless Phone
Gigaset 2420 Siemens
You may have the wrong or defective power supply. Or, that problem is common from getting a power surge and the unit will probably have to be sent in for repair, sorry.
May 05, 2008 | Siemens Gigaset 2420 Cordless Phone
Siemens 2420 Phone System
I had the same issue a while back and I believe a new power supply fixed that problem. If you know anyone with a multi-meter and they know how to use one they can tell you if your power supply is bad or not putting out enough voltage. I believe this system requires 12 volts and 400 milliamps it will say on your current power supply.
Aug 31, 2007 | Siemens Gigaset 2420 Phone
Siemens Gigaset 2420 Desk Staion LCD Display
That is a common problem with those types of displays, they are sensitive to heat, cold and any movement. They were used by Siemens, and almost all the other manufacturers during this time period. Unfortunately on this particular model, they are not soldered in, they are pressed on by a machine. So if you don't have a Zebra cable press machine ($1000's), and a brand new display, you can only resort to sending it in for repair. Sorry.
Apr 28, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
645 people viewed this question
Top Siemens Lands Phones Experts
Marvin
Marvin
Jaime Hernandez
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
