Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubishi ws-65819 I have a 7 year old Mits that is having the bowtie problem. I was told this was probably convergence IC's and was quoted between $250-400 to fix it. I saw a previous post about replacing them with STK-392-110's which sell for $13 a piece. Is this the correct IC part number for my TV and is this something a novice can do? I'd rather get a new TV if the repair is close to $400 bucks. Thanks for your help!
  • grazyclif May 13, 2008
    HI I change both the STK392-570 that you
    talked about if your haveing a convergence problem and it got worse do
    you think that I may have acquired a bad set of chips they are not oem
    chips they are aftermarket I now cannot move the red or the blue from
    side to side and at the bottom of the screen the pic is in a frown the
    cross hairs are lined up for the blue and the red but on the next
    alligenment menu its way off on the right side and way off on the left
    and I cant move anything before I change the chips I could tap on them
    and it would almost stragten up do you think should I order new chips
    from
    Mitsubishi thanks David, [email protected]
    Comment by grazyclif, posted on May 13, 2008hi
    I wanted to had that I have tired to do service realignment also with
    no luck could it be the pico fuse and I think I heard there is
    something around the chips I changed that may be bad or again I say are
    the stk-392-570 chips bad and is this t.v really worth all this trouble
    any help would be great thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
The correct part# for the two convergence ic's is = STK392-570. The repair is close to $400
Posted on Aug 22, 2007
SOURCE:
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
Mitusbishi Model ws-65819 color convergence repair. How does one go about fixing it?
The two stk-392=570 chips need to both be replaced===they are along with the rest of the circuit on the middle board.
May 20, 2012 | Mitsubishi WS-65819 TV
I have a 65inch mitsubisihi and having convergence problems need help on instructions to put in stk-392-570 chips to fix the problem. WS-65819
Here is a youtube video I found that was quite helpful to repair my WS-65819 this weekend: http://www.youtube.com/watch?v=63TbxQaNkVo
There is a part 2 that deals specifically with the soldering of the chips. Hope this helps
Sep 26, 2011 | Mitsubishi WS-65819 TV
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Screen is arching at bottom of screen. only does when you first turn it on after 10 0r 15 minutes it fixes itself
This is the begining of a convergence problem and the O/p IC' will probably need replacing.
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
Convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 06, 2009 | Mitsubishi WS-65819 TV
Mod. WS-655111 Fuse F9A04 & 05 bad. Set goes on & right off
You can order a replacement STK393-110 for this model (62HM95) from a major parts distributor at the link below:
Mitsubishi WS-65511 Replacement Part Convergence IC STK393-110
You would probably have to recalibrate the convergence after you install the IC. There may be a convergence kit available as well.
Apr 10, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Intermittent convergence issue became permanent
Hi Ed,
Your convergence amplifiers are definitely bad. The user manual will not work, since it is the same manual that comes with the set when it was new. The service manual can be found at:
http://servicemanuals.net/results.aspx?type=SM&brand=0&model=WS-65819
Best Regards,
MyTvGuy
P.S. Thanks in advance for rating me!
Feb 09, 2008 | Mitsubishi WS-65819 TV
Arched or bowtie effect
You have bad convergence Ics they are mitsubishi part # 267P150010 Generic part is STK 392-570 and they are at locations Ic8c01 and Ic8co2 on the deflection board. If you can solder you can take these out replace them and fix your problem for about 100 dollars. Best of luck
Josh
Feb 08, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 got Fried by a mouse
Just replacing the board if its the main board is half of the repair. The memory IC which is usually located on the main board holds all the data for convergence,picture geometry,channel memory,color settings etc..So getting it to run is only half of the battle. Got to http://www.partstore.com and look for the main board. I couldn't however look it up because it says your model number is invalid.
Mar 14, 2007 | Mitsubishi WS-65819 TV
Televison & Video Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
