There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer.
Step one: Check the virtual memory settings
Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue.
Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties .
Click the Advanced tab.
In the Performance section, click Settings .
In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive.
If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over.
The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box.
The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting.
Change the settings as necessary to conform to the information in this step.
Click Set , and then click OK .
Try printing again.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files
Follow these steps to run Disk Cleanup.
Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean.
Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report.
Select the following items from the report:
Temporary Internet Files
Downloaded Program Files
Recycle Bin
Temporary Files
Click OK .
If the issue persists , see the next step.
Step three: Remove unnecessary software programs
Follow these steps to remove unnecessary software programs.
Click Start , click Settings , click Control Panel , and then click Add/Remove Programs .
Select a software program to remove, and then click Add/Remove .
Repeat these steps for all software programs you want to remove.
If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Installed from cd fine, but get same error message when program is launched.
The problem: Could not initialize the program, because there is not enough memory available to run. Code= -30202 In fact there is enought memory available. How to fix the problem?
