Question about Lasonic DVD-3200 DVD Player
Lasonic dvd player
The dvd tray will not open when I push the open/close button. The unit thinks the tray has opened and a disk has been inserted. The unit worked fine 1 day, and 2 days later, it will not open. Thanks
SOURCE:
  • 61 Answers
SOURCE: Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Posted on Jan 27, 2008
SOURCE: Samsung BP-1500 problems When I tried
Just contacted manufacturer with same problem.....your unit needs to be updated....check website...can be done with flash drive or burn a cd
Posted on Jan 31, 2009
SOURCE: Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
Posted on Dec 03, 2009
Sparky2012
  • 102 Answers
SOURCE: I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Posted on Dec 04, 2009
supertech6
  • 513 Answers
SOURCE: dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
Posted on Apr 03, 2010
Open/Close disc tray, would not open
your unit might have a child lock device.some units have this option.check the manual if you have one.if it dosen't there may be a fault with the open/close button.
Feb 15, 2015 | Samsung DVD-V1000 DVD Player/VCR
Tip
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
/SciPhinx
on May 06, 2010 | Televison & Video
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
Tray confused
I have an LG DVD player and recorder model # RC7423W and i have a similar problem, when i open up the disk tray it displays open and the tray opens for 2 seconds only and then closes. when i press the open/close button to open it again it opens and never closes back with a "Disc Error" on display until i close it manually by pushing it back inside.
I cleaned it from dust many times and tried to reset it but no reset button. i just tried to unplug the wire and plug it back.
let me know if there is a way that i can reset the hardware or a solution to my problem. my system is around one year old
Oct 22, 2007 | LG DR787T DVD Recorder
DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Jun 20, 2007 | Zenith XBV443 DVD Player/VCR
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Lasonic DVD-3200 DVD Player Logo
Top Lasonic Televison & Video Experts
JOHN TOPLISS
NOEL
NOEL
da surgen
Are you a Lasonic Televison and Video Expert? Answer questions, earn points and help others
