Home | Danby | DDR583R Dehumidifier | My direct drain doe...
Danby DDR583R Dehumidifier
Problem for Danby DDR583R Dehumidifier
My direct drain doesn't work anymore
By vermont on Aug 21, 2007
I have the dehumidifier set with a hose drain in the back but suddenly it is defaulting to the water tank in the front and I have to constantly empty it.
Best Solution
posted on Nov 22, 2007
Helpful)
alecs_80
Rank: Apprentice
Rating: 93%, 3 votes
I fixed the same problem, finally. At first it was sufficient to clean the outside hose (it was filled with a limey builtup). Then it stopped working again. I decided to open the unit and see how easy it is to clean the inside drain hose. It is very easy. Once you unscrew the back panel (8 screws total if i remember correctly) you can access the back and you see the drain hose that connects to the drain outlet. To remove it and clean it, you will have to unfasten the big capacitor (3 screws). Then, remove the hose and clean it (mine was full of that same limey stuff). Reinstall - you will need a tie wrap to connect the hose at the top, as it is from the factory. Very easy operation and now the dehumidifier is draining again.
Comments:
Nov 22, 2007
- Also, when i see those big capacitors i tend not to touch their terminals, they can be charged enough that you could get shocked. So, watch it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Danby DDR583R Dehumidifier
Questions and Unsolved Problems for Danby DDR583R Dehumidifier
Do you recommend Danby DDR583R Dehumidifier?
Answer
Answer
After a lengthy period of inactivity, we came to use the dehumidifier and noticed that the LED... (More)
Answer
I have been emptying the tank few times a day, because I had no convenient drain in basement. Now, I... (More)
Answer
Model DDR6588EE - called Danby and they will not tell me what part I need or how I can order it due... (More)
Answer
My unit is collecting moisture VERY WELL! BUT it blows warm air only which makes it very hot in our... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR583R Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
