Question about Toshiba Satellite A135-S2276 Notebook
Bios password I have gotten my bios password of my laptop toshiba satelite pro 30-rv 2 . how can i reset it
  • 1 more comment
  • sbyind Apr 09, 2009
    please show me pasword to open bios set up of dynasatellite ( toshiba )
  • Anonymous Apr 10, 2009
    pls show e password to open bios set up for dyna satellite A136S-2276
  • Anonymous Mar 19, 2014
    change password on my toshiba satelite laptop
On a desktop you remove the battery from mother board leave it out for 1 hour it resets the board and removes the password it should do the same on a laptop
Posted on Aug 21, 2007
SOURCE:
How to reset bios password on toshiba satelite c650-15m
To demonstrate, I shall need proof of ownership first, so take it to a repair shop, prove ownership and they will be able to reset the bios password for you at a fee.
Feb 07, 2015 | Toshiba Computers & Internet
Toshiba satelite L45-4687 bios password lost
You will need to open the Toshiba case, then find and remove the battery from the motherboard for a few minutes before replacing it. Some Toshiba laptops have a BIOS reset switch on the motherboard. In both cases you need to open the laptop case to solve your problem.
Jan 13, 2014 | Toshiba Satellite Computers & Internet
TOSHIBA SATELITE 1415-S115
There is no way you can bypass, if you are the original owner Toshiba will reset bios for $100. not cheap, go to www.ebay.com type bios password and you will be presented with a list, "choose carefully" not all are lagit. Next check www.download.com and type same info, and lastly! www.pwcrack.com I hope you can get the support.
Mar 22, 2012 | Computers & Internet
Bios password toshiba satelite l300
Method 1 (Flash BIOS)
Flash BIOS for Satellite L300-ST2501
Flash BIOS for Satellite L300-ST3502
1. Remove the battery and don't turn on the laptop (a minimum of one day or more). To remove electric current, which is still stored in the laptop. Based on experience, can turn a normal laptop, try to enter windows.
2. Download Flash BIOS slb0v150.exe then open the file, select Install, and select Install from Windows - OK.
Flash BIOS can remove the BIOS password
Method 2 (Manual)
source image : bios-repair
With solder, remove the BIOS IC, wait about 10 seconds, then plug it back. To remove the BIOS IC, you must remove the screws down and the LCD.
I hope this information helpful.
Oct 20, 2011 | Toshiba Satellite Pro L300 Notebook
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
How to reset hard drive password, toshiba sattlite reset forgotten hard drive password,satelite. L655D S5093
Chris Hingee is absolutely correct. Even if you reset the laptop bios password, you will not be able to reset the hard drive bios password. That old hard drive is your new paper weight after you purchase a new hard drive.
Apr 15, 2011 | Toshiba Satellite L655D-S5093 Laptop
How to reset cmoss password in toshiba satelite A135-S2276 service manual
You can try some BIOS hacks, just google them. Or you can try and take your laptop apart (use the manual), locate the BIOS battery, take it out and leave it for 5-10 minutes and the password should be reset either to default or nothing.
Jan 12, 2011 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite pro l 350 bios password reset
This is the ONLY other way, save paying Toshiba and filling in proof of ownership forms.
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Feb 20, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Satelite A55-S306 Password removal
hank you for your quick response. Yes, it is the BIOS Password.
Jun 11, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
253 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
