Question about HP iPAQ RX3715 Pocket PC
Outlook Before I get started all just come out and say, I am very ignorant when it comes to computers. I?ve had this iPAQ for a couple of years now and it?s worked great. For some reason it will not sync with my new laptop (Dell Latitude 120L) that I received a few weeks ago. Let me rephrase, the Tasks, Nots and Files sync just fine; it?s the Calendar and Contacts that I?m having a problem with. When I sync my iPAQ with my PC the calendar and contacts say (sync status on device). Please advise thanks, Adam G. [email protected]
Check the setting on the ipaq, go to ActiveSync and tools, options, server and make sure calendar, contacts and inbox are not selected here. Then, put the pda in its cradle and let it do a sync, it should change the settings on the desktop and the (sync status on device) should disappear. I had a similar problem and after de-selecting these, everything worked fine.
Posted on Sep 02, 2007
SOURCE:
I am trying to hook up my hp ipaq model h1910 to my emachine D6419 and it says to hook it up to Com 3 port on the back of my computer. How can I find out where that is on the back of my emachine? I lost...
Connect to a Computer
You can wirelessly connect to your personal computer using an infrared connection.
You can physically connect your iPAQ Pocket PC to your personal computer using Microsoft ActiveSync and a USB cable.
You must have Microsoft Outlook to operate your iPAQ Pocket PC using Microsoft ActiveSync on your computer. If you do not have Outlook, install the Microsoft Outlook software from the HP iPAQ Pocket PC Companion CD.
Microsoft Outlook Express will not work with the iPAQ Pocket PC and ActiveSync.
What book/manual are you talking about?
emachine D6419 can be found at;
http://global-download.gateway.com/GDFiles/Document/User%20Manual/User%20Manual_eMachines_1.0_A_A.zip?acerid=633933437244339685&Step1=DESKTOP&Step2=D SERIES&Step3=D6419&OS=ALL&LC=en&BC=EMACHINES&SC=PA_6E
hp iPAQ Pocket PC h1910 - Reference Guide at;
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002238.pdf.
Good luck and post back.
Jun 03, 2011 | Computers & Internet
Appointments off by one hour after DST
did you get the update for the new DST shift that happened a week early this year?
Mar 16, 2008 | HP iPAQ rx1950 Pocket PC
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
HP iPAQ 2215 sync problems with Vista and Windows Mobile 6.1
I've decided to get a smartphone with Windows Mobile 6.1, so this issue has been "solved"
Feb 08, 2009 | HP iPAQ 612C Smartphone
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
When I connect my iPAQ to my PC, it will not recognize the device
It shouldn?t take more than 10 to 15 seconds for Active Sync to detect the iPAQ once it is inserted in the cradle and it turns on. First off you need to update to the latest version of Active Sync which is 4.5. Lots of synchronization issues have been fixed since 3.7 so here is the link to the download: http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en A couple of times over the past few years I?ve gotten a non recognition error as well. Each time I?ve been able to get away with removing and installing the latest version and my problem has been solved.
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
Synchronizing with Outlook
It has to be set upo to be your defualt email program for the sync to work..... In OUTLOOK on your PC click on Tools, Option, Other check the box 'Make Outlook default Email Program'
Sep 14, 2005 | HP iPAQ RZ1715 Pocket PC
Send/Receive Mail with iPAQ
Did you select your account from the Accounts menu?
Sep 14, 2005 | HP iPAQ HX2415 Pocket PC
Outlook 2002 Reinstallation
The default e-mail client on pocketPC 2003 is the "inbox" which is merly a utility for retreiving & sending e-mail. There is no "outlook 2002" on pocket PC's. The Outlook 2002 installation cd comes with most iPaqs and is intended for your pc, not your ipaq.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Contents of outlook
No, an install of OUTLOOK over OUTLOOK data will NOT lose the data. However... you may want to backup the files first ?? What version of OUTLOOK are you currently running ? If it's already 2002, I might be tempted to ignore this message.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
125 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
