We have replaced the drivers side window switch twice, keeps shorting out the switch?
Vehicle? Do all the windows work when the switch is replaced? How long does it last? Are one of the other switches stuck in position?Do all the other swicthes seem okay?On gm they all run through drivers side. Some systems are different. From the drivers side to say the passenger side front there are two wires that switch polarity between up and down. one wire is negative for up and positive for down, the other wire acts exact opposite. the other system the motor is grounded and there is a positive for up and a positive for down and no ground runs through. but I would say a bad door seal somewhere(bottom of driver window,at hinge tube conduit, or between door and vehicle up by windshield as water will follow seal around to inside of door)of if its a ford could be a gem module problem.
SOURCE: 2003 Mitsubishi Eclipse RS, driver side window won't work.
test at the motor inside the door to see if you have power ,could be the motor itself
SOURCE: 1999 Dodge Durango driver side window does not roll up nor down.
Remove the door panel and find the window motor Unplug it and using a separate car battery run cables directly to the window motor When you switch the polarity the motor will either bring the window up or down or if noting happened change the window motor and window regulator assembly.
SOURCE: electrical problems with window switch
Usully caused by a wire rubbed through. Common areas are within a few inces of switch, at window channel bracket inside door or where wires pass into car behind kick panel
SOURCE: replace window switch for 1997 el dorado
I have the same problem. I just replaced the switch ($60 from the Internet) Easy replacement, but the problem persists, Here is my next plan of attack... The PCM (vehicle computer controls the power windows for your vehicle. check the power window relay under the hood before repairing PCM. Also the cheapest way is to call local garage and ask if they have a TECH2 scanner to talk to the PCM. The Dealer will charge you about $95hr. to do this.
