Question about NEC Electra Elite 32D-1 Corded Phone
Ring and paging system
We had a power surge through the whole office. The phone now only rings in the front office and all paging numbers were erased. I need to reprogram the paging systems and cause the phones to ring everywhere. Help!
    Problem Solver:
  • 9 Answers
Suggest to find your local nec dealer.i think you probably solve this problem already. other than that. do 51 for internal paging. 55 for external paging, if need to program all the phoen to ring.,you can do the copy mode.if you still need help on doing that. sjcom
Posted on Sep 01, 2007
    Novelist:
  • 201 Answers
I have seen cases where programming can be messed up or even set back to default with rapid on-off-on-off power surges that often happen in power outages. The system will need to be re-programmed. I have never programmed an NEC system but here is what you need. Either find a local installation company that can fix this for you OR figure out which NEC phone system you have and locate the Programming and Installation manual for it. (not a user guide or administrator's manual) The phone's part number will not help you figure out which NEC system you have, it only narrows it down a bit. Look for the main control unit in the basement, utility closet, etc.. Programming any phone system can be daunting for someone who has not done it before even with the right manuals. If you are not up to it, look for a company that can help. MAKE SURE the system is defaulted before re-programming it! There could be a glitch in the programming that cannot be fixed without a system default so you want to do this before making any changes. Also, I would highly suggest a UPS backup power supply for the phone system. This will keep it running for a short time in a power outage and will stop this from happening again. If you have a small system with 1-12 phones, most small UPS systems made for computers will work. Small phone systems use less power than a computer and monitor.
Posted on Aug 22, 2007
SOURCE:
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Hello. Often the aftermath of a power outage is a power surge. If your phone system is not surge protected, this is the likely culprit. The damage done by a surge or several surges can only be assessed with a thorough diagnostic exploration. This has to be done by a technician with the proper diagnostic equipment and know how. j.
Jun 14, 2010 | Samsung Prostar 816 Phone
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
Jun 01, 2010 | Samsung Prostar 816 Phone
Small office system - when paging another person,
AFAIK, there is no way to turn of the ringer for only paging.
Feb 18, 2009 | Uniden 5.8GHz Dual Cordless Phone
Muted ring tones
pl mention ur model no & make of the system
Jan 28, 2009 | Lands Phones
Be able to pick up incoming calls from all front office phone sta
Get a copy of the manual here
http://www.cactcom.com/Manuals/Vodavi/Vodavi%20DHS/Vodavi%20Starplus%20DHS%20Installation%20And%20Maint%201995.PDF
Looks like you can group the stations together and then any one of them can answer incoming calls. See page 45 or so.
Jan 22, 2009 | Vodavi Starplus SP7314-08 Corded Phone
No ring for some phones after power outage- dks 930 phones
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Dec 24, 2008 | Southwestern Bell Landmark DKS930 Corded...
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
NEC Electra Elite 32D-1 Corded Phone Logo
476 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
