Question about Bissell 1685 PowerSteamer Vacuum
Bissell power steamer turbo
Flow indicator will not turn no cleaning agent getting thru
  • 1 more comment
  • grixter Oct 10, 2008
    I was using the vacuum and everything had been working fine, it was time to change the water and add more cleaning solution, so I turned it off and emptied the dirty water. I filled up the water container with clean, hot water and filled the the cleaning solution container. I installed like I have a hundred times before and the indicator wasn't spinning nor was any cleaning solution coming out.
    Please help - I really love my PowerSteamer Vacuum and need to use it very soon !!!
  • Anonymous Mar 14, 2014
    How to take apart a bissell quick steamer powerbrush to clean it
  • Anonymous Mar 16, 2014
    Saw that someone I loaned it to stuck a long wood q-tip to clean it out thinking it would spin and broke it off in the tube.
    Scholar:
  • 33 Answers
Mine does that, too. Pushing down and wiggling the tank usually gets it going. Also, it doesn't seem to work when the soap bottle is low, even when the soap is turned off. I fill the bottle with water. It is easy to take the top off. Mine has just 6 screws. Then you can see all the tubing and parts. For example, you can unclip the nozzles and see if water flows. Try blowing through the nozzle to see if it is plugged. Some people say the heating unit in the handle plugs up, particularly if you put soap in the water tank. I haven't dealt with this, but it should be easy to open the handle and bypass the heating unit.
Posted on Sep 11, 2007
SOURCE:
Bissell instruction manuals
The instructions tell you to clean filters after each use. Check the User's Guide for specifics. Quick guide though. Water tank Cap: Under the cap is filter (looks like a screen) remove, clean, replace. Locate the Flow Indicator: turn it counter-clockwise to remove the cap. Lift out the rotor and the filter underneath, Clean and reinstall in reverse order. That should fix the problem. Consumer Care phone number is listed in the User's Guide.
Aug 20, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why isn't the soap coming out of the despencer
Check dispenser seating, turn off unit, unplug unit. Reseat dispenser, plug in unit, turn unit on, wait one minute, press sprayer to test. While your at it clean the two filters. The filters need to be cleaned after each use. One is located under the Water Tank Cap and the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jun 23, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat Problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hfjk
May 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No sign of water movement from cleaning heads
My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Power Steamer Proheat Plus not dispensing
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1685 PowerSteamer Vacuum Logo
308 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
