Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HPL7780 and Linksys WRT54GS V7
Upon inputting the WEP password for a wireless network the printer states it is active on the network but instantly freezes and has to actually be reset by pushes the 6 and # key while unplugging and then reinserting the power cord. You can't even turn it off or unplug it to break the freeze. HP says it has something to do with the Linksys wireless router. Any clues? I know it won't hold a manually input IP address. It constantly resets to all zeros. Any word on what may fix this issue?
  • mjbelville Apr 24, 2008
    I am having the same problem. I have the same Linksys router and the printer freezes everytime I connect to the wireless network. I am able to connect a network cable direct from my printer to the router and have no problems but as soon as I disconnect the printer freezes.
    Novelist:
  • 106 Answers
That usually happens when you are going to connect the printer PRO using the wireless. To avoid that problem, try connecting the Printer using the Manual Setting of the IP.
Solution
NOTE: If the router has an outdated or firmware that was not supplied by the manufacturer, update the router to the latest manufacturer-supplied firmware. Set a Manual IP address on the HP All-in-One
  1. Change the IP settings to Manual from the HP All-in-One.
    1. On the front panel of the HP All-in-One, press Setup .
    2. Press the left arrow button (HPL7780 and Linksys WRT54GS V7 - c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Network , and then press OK .
    3. Press the left arrow buttonHPL7780 and Linksys WRT54GS V7 - c01135026.jpgttp://i.fixya.net/uploads/images/c01135026.jpg" alt="c01135026.jpg" class="h_mi"HPL7780 and Linksys WRT54GS V7 - c01135027.jpge right arrow button (c01135027.jpg ) to select Advanced Settings , and then press OHPL7780 and Linksys WRT54GS V7 - c01135026.jpg
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) or the right arrow button (c01135027.jpg ) to select Manual , and then press OK .
  2. Set the IP settings from the Manual IP Settings menu using the following instructions. For this item... Do the following... IP Address Type a manual IP address on the same subnet, but outside of the DHCP range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway.
  3. Run the Wireless Setup wizard and try to associate the HP All-in-One to the wireless network.
Workarounds Connect the HP All-in-One via a Wired Network
  1. Disable Wireless Radio. FollHPL7780 and Linksys WRT54GS V7 - c01135026.jpgs to turn off Wireless Radio.
    1. On the front panel oHPL7780 and Linksys WRT54GS V7 - c01135027.jpgin-One, press Setup .
    2. Press the left arrow button (c01135026.HPL7780 and Linksys WRT54GS V7 - c01135026.jpg_mi ) or the right arrow button (c01135027.jpg ) to select Network , and then press OK .
    3. Press the left arrow button (c01135026.jpg ) or the right aHPL7780 and Linksys WRT54GS V7 - c01135027.jpgc01135027.jpg ) to select Advanced Settings , and then press OK .
    4. HPL7780 and Linksys WRT54GS V7 - c01135026.jpg_mi"> Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Wireless Radio , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Off , and then press OK .
  2. Connect an Ethernet Cable to the RJ-45 connector at the back of the HP All-in-One. Connect the other end of the Ethernet cable to one of the LAN ports of the router.
  3. Turn off the HP All-in-One by pressing the Power button. Turn on thHPL7780 and Linksys WRT54GS V7 - c01155210.jpgne again.
Connect the HP All-in-One via Ad Hoc Wireless Network
  1. On the HP All-in-One control panel, press Setup .
  2. Use the down arrow button (c01155210.jpg Use the down arrow button (c01155210.jpg ) to highlight Wireless Setup Wizard , and press OK . The Setup wizard searches for available networks, and the color graphics display shows a list of detected wireless network names (SSIDs).
  3. Use the down arrow button (c01155210.jpg ) to highlight your wireless network SSID, and press OK . If any encryption is configured in the computer, the wizard will prompt for the WEP key.
  4. Highlight the letter or number on the visual keyboard, and press OK .
  5. Highlight Done on the visual keyboard, and press OK .
  6. Press OK again to confirm the settings. The HP All-in-One will try to connect to the wireless network. Once the wireless network is successfully setup, a message should appear stating that the connection has been successful.
  7. Press OK .
Source: www.hp.com
To get the technical document click here ==>> Document
Please let me know if the issue wont resolve the problem so that we can go ahead and do another workaround.
thank you.
adonscott
Posted on Jul 04, 2008
Actually, the best thing to do is disable the ethernet. There is a firmware problem on this model printer. By disabling the ethernet the wireless will work just fine.
Posted on May 17, 2008
Where is black ink cartridge located
Posted on Jan 11, 2008
What you want to do is first connect to the network by plugging it in to the lan (not wireless). Go through configuration, select wireless, and click temporarily connect through lan. Configure the wireless network there, and you'll be good to go.
Posted on Dec 26, 2007
No enternet access
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver.
Restarting the computer corrects this issue.
hope this helps
Sep 26, 2012 | Linksys Wirless Router Wrt54gs V7 Router...
How can I secure my wireless connection?
By using a WEP key, please find your manual below, download it, and go to SECURITY, it shows one step by step how to set your WAP/WEP "KEY" Once set, you are secure. As to logon to the WiFi network, you need the special "KEY" to do so.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Nov 24, 2010 | Linksys Wireless-G WRT54GS Router...
We went from a windows xp to windows 7 and now our linksys won't work. it comes up error 322. help. model # WRT54GS v7.2
NOTE: For instructions on how to "Get Downloads" from Linksys Support site, click here.
Connecting to Wireless Networks Using Windows 7's WLAN Autoconfig
Follow the steps to connect to your wireless network using Windows 7's Autoconfig.
Step 1:
Click on this icon kb20600-001_en.png at the bottom-right of the screen and you will see a list of available wireless networks.
Step 2:
Select your wireless network's name or SSID then click Connect.
NOTE: If the wireless network's name or SSID is not listed, the SSID broadcast on the router is disabled. To connect to the wireless network with SSID broadcast disabled, click here.
If the computer does not connect, it is probably because the computer cannot detect any signal or cannot see any wireless network. In this case, you should change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
Step 3:
You will be prompted for your wireless network's security key. Click OK after entering your security key.
Step 4:
You will see the following screen and you will be soon connected to your wireless network.
I need to find my linksys wep key for my home network
Plug your PC into the router using a standard ethernet cable. Log in to the router's configuration screens by bring up a browser and typing in the router's IP address (generally the same as the IP address your PC obtains from the router, except the last portion is replaced with "1"). Navigate to the "wireless security" portion of the configuration utility, and either read off your current WEP key, or (if it shows only as little dots) replace the WEP key with a new one that you can remember.
May 16, 2010 | Linksys Wireless-G WRT54GS Router...
Where do I find the Network name SSID and WEP or
192 168 99 type this into the address bar at the very topof the windows internet explorer (the http;// bit) hope this helps
May 15, 2010 | Linksys Wireless-G WRT54G Router
Setting up linksys wireless router security wep . Linksys WRT54gs V.5 router. I reset it back to factory defaults. Now I want to make it secure again.
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 07, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot get a second computer on my secure wireless network
Have you set the properties on the second computer to match the security expected by the router? Since one computer works I would compare the settings for the network connection and set the second computer to the same.
Mar 15, 2009 | Linksys Wireless-G WRT54GS Router...
Secerity key
Just go to www.linksys.com/kb select the model no.of your router and you will get step by step help to setup your router. you can also call linksys tech. support and i am here to solve your problem.
if this is a new router then connect it to your system through ethernet cable and go to internet explorer and type 192.168.1.1 at the add. bar it will prompt for the password. leave the user blank and type admin in the password linksys setup page should open. now click on the WIRELESS TAB and on the basic wireless settings change the defale SSID NAME to your girlfriend's name and also click on reset security and click on save settings. reload the page and now go to wireless security tab and select WEP in the security tab. now type 10character password in the KEY 1 field directly and click on SAVE SETTINGS and that's it. Now when you connect to your network you will have to enter your 10 char password in your COMPUTER and it should work fine now. call tech support or go to the above link for further assistanceRICHARDM69
Dec 04, 2008 | Linksys Wireless-G WRT54GS Router...
Initial wireless activation freezes unit
Beth, Any details on what firmware version worked for you. Have a WRT54GS V7 -- and having same darn issue!! - Jen
Aug 16, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
1,051 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
