GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Beeping, f0 reading
By jlr1060 on Aug 21, 2007
I don't don't know what f0 means. I can't find my manual. I having constant beeping with the face reading f0 and sometimes f7.
thanks for your time,
Judy
Same Problem
Apr 23, 2008
-   I have a GE profile smooth top stove with flat panel control for the oven. A couple hours after finishing some baking, the oven starts to beep and the F0 code appears. I left it for a couple of hours and begun hitting random buttons. The keypad started to respond so I tried to turn the oven on, which it did. Today, I wanted to self clean the oven. I set it to the 4hr cycle and it began. However, after about 30 minutes, it started beeping again, and it displayed the same error code again. My husband turned off the main breaker for 40 minutes and after doing so, the oven display came back on without the error code, so I started the self clean cycle again. It stopped and showed the error code again and will not function. The stove top does work though. What does the F0 error code mean, and how much $$ am I looking at to fix it? PS- this is barely 4 yrs old along with my other GE profile appliances in my home. All but the dryer have had issues. I am very disappointed at the cost of these appliances and how well they have lasted. Thanks for your assistance, Amber-   ge_blowz
Best Solution
posted on Apr 16, 2008
Very Helpful)
Tiger509
Rank: Apprentice
Rating: 96%, 22 votes
Was this helpful?
Yes
No
19 people thought this was helpful
Solution #2
posted on Aug 22, 2007
Somewhat Helpful)
SolutionGuy
Rank: Guru  GE Expert
Rating: 95%, 646 votes
Judy, I'm sorry to be the one to tell you this, F0 indicates a failed thermister control. The solution is to replace the Electronic Relay Control (ERC, sometimes called a "clock"). F7 can be one of two things, 1.) Failed keypad or 2.) Failed ERC. Since you have F0 AND F7 error codes, you'll be looking at replacing the ERC.
These are extremely pricey, unfortunately. You'll need to get the entire model number and serial number. These are located at the bottom of your oven... pull the drawer out and you'll see the data tag down there. After you have those numbers, call your local appliance parts retailer for a price. It'll be around $175, just for the ERC.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Apr 24, 2008
Somewhat Helpful)
hsimons
Rank: Guide
Rating: 72%, 21 votes
I would this that it is more likely that the f0,f7 codes are more indicative of a defective touchpad.Both of these codes can be caused by shorted circuits in the touchpad. We actually rebuild electronic range controls ( among other things)
Regards,
Howard
http://www.appliancetimers.com
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
I have just had the 'dual fuel' unit installed, but the electric burner is not coming on. Am I doing... (More)
Answer
When a GE Profile oven broiler element burns out does it cause the bake to also not work?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Range Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
