Candy AQW130 Front Load All-in-One Washer / Dryer
Problem for Candy AQW130 Front Load All-in-One Washer / Dryer
Dryer - acquaviva 1300 - how it works?
By gracielahd on Aug 21, 2007
Hello
How does the dryer work out? I can't make it dry the clothes.
Many thanks
Same Problem
Sep 24, 2008
-   the clothes wont dry-   wee janelle
Sep 05, 2008
-   it heats up but doesnt stay on long enough to dry the clothes which dial do i set it to make it stay on to dry the clothes it goes off after a couple of minutes-   andy123a
Best Solution
posted on Aug 22, 2007
Helpful)
gittos73
Rank: Guru
Rating: 87%, 300 votes
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Was this helpful?
Yes
No
Solution #2
posted on Sep 24, 2008
Not Rated)
wee janelle
Rank: Apprentice
Rating: 0%, 0 votes
wats all da settings for the washer dryer and we have da same probem with are 1 it washes the clothes but when it comes to drying them it dont work could u tell us wahts goin on with it
Was this helpful?
Yes
No
Popular Solutions for Candy AQW130 Front Load
Questions and Unsolved Problems for Candy AQW130 Front Load
Do you recommend Candy AQW130 Front Load All-in-One Washer / Dryer?
Answer
Answer
Candy Aquaviva 1300: which ever program is selected the machine seems to do part of the wash then... (More)
Answer
Where do i get the tool to replace drum bearings for candy washing machine
Answer
hi, our candy aqua 1000T trips its fuse somewhat arbitrarilly. sometimes it works fine for wash... (More)
Answer
The machine washes OK, drains OK, and the drum seems to turn (slowly) during the cycle. However, it... (More)
Answer
There is excessive play on the drum mechanism and the rubber (possibly called the door seal) has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
