Question about GE Profile Prodigy WPSE4200A
Not draining the tub fills with water and then just stops.
  • sange Aug 23, 2007
    HI, the belt isn't broken and the motor still spins. It just doesn't want to drain...except on my floor.
It will be nice if you will let us know how did you solved your problem !
Posted on Aug 28, 2007
  • 641 Answers
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Posted on Aug 22, 2007
  • Dov Dror Aug 23, 2007
    Your washer probably has a pump problem.
    Check first for 115/220V on pump's tags.
    In case you can read 115/220V on its tags,you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely (frozen or stiff),look for foreign objects, if it still will not turns freely it should be replaced.
Moffat washer
Your water level has a reset on the panel? You need to drain all the water out of the tub and turn the water level to the lowest setting. Now start the fill and watch the water come up. It may be that it needs to be looked at but it is just a hose on the side of the tub that fills and air pressure registers in the control panel that stops the water filling.
Jan 08, 2014 | Washing Machines
Water will not stop running into washer
one of 2 things can do this,first unplug the unit from the power if it continues to fill then its the water fill valve thats bad,second if it stops filling when unplugged from the power outlet then its probably a plugged pressure switch line from the tub so the water pressure cannot switch the pressure switch diaphram from fill to wash cycle,open the cover and remove the pressure hose from the tub and blow into it and you will hear a click in the pressure switch its connected to,then replace hose onto tub side and blow into the other end of this same hose and make sure theres air movement in the tub as you will see and hear bubbling noise
Jun 03, 2012 | Samsung WF448AAP Front Load Washer
Water fill doesn't stop filling cold water
check washer pressure vale and the tube connect from the tub to pressure vale most of the time the mouse bite the hose some where in the panel con trol of the washer good luck
Mar 03, 2010 | Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
What would cause the washer to overfill the tub?
If water is overflowing and you disconnect power to the machine. then:
A. It continues to fill: Replace water fill valve. (the part the fill hoses screw onto)
B. It stops filling: Most likely has a plugged tube from the tub to the water level switch.
Jul 27, 2009 | Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Maytag performa not recognizing when to stop filling with water
be sure the rubber hose runnig from the water level switch to the tub is conected on both ends if not conected to the tub the water will come out the hole the hose is supposed to be conected to and it want stop filling.
Jan 21, 2009 | Maytag Washing Machines
When water level is above the handle on the wall it goes down
The cover is called a trip lever and Over flow to stop you from over filling the tub or when you get in the tub to equalise the water level. And prevent water from pouring down on the floor
Mark
Dec 23, 2008 | Kohler Home
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
