Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
I have a GE Spacesaver--turns on, all seems fine, but doesn't heat. Tried to check the power level, says "power level cannot be changed at this time" Any ideas?
  • Anonymous Jan 02, 2009
    The microwave runs but does not heat. The power level button says power level can not be changed at this time.
If you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Posted on Sep 03, 2007
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My oven heated fine 2 days ago and the kids tried to heat some sandwichs last night and it didnt heat. The table turns, clock counted down and power setting on level 10. I boiled water this morning to...
after several reviews of this microwave i have found that most people are not satisfied with the model or the company. And that it seems that your problem may consist with the magnetron not being installed correctly sometimes this happens at the factory but can only be replaced by a technician. they are supposed to carry them on their truck at all times. Youll have to call GE and schedule an appt with a tech. and from other testimonies that can prove to be difficult. sorry i couldnt have been of more help and good luck
Jan 25, 2011 | GE JVM1850 1000 Watts Microwave Oven
Ge spacesaver jvm1540 it runs, lights, fan works, just no heat. then slow heat, now heat again, but seems to take longer? please help
Sorry to read about your problem, I hope this helps you out.
it seems you may have defective magnetron, I suggest you contact a service company, that has the proper tools to check the problem...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
Do commercial microwaves have some sort of feedback loop designed to reduce power when they are insufficiently loaded? In particular, I'm using a GE Spacesaver for a little science experiment where we...
HI,,
ITS A PROBLEM WITH DISCONTINUE VOLTAGE..
USUELLY COMMERCIAL MICR WV COME WITH IMPROPER HEAT OUT,,
FOR EXAMPLE IF U PUT TEMP ON 100 FHT IT WILL GIVE OUT 80 FHT..
SO I PREFER A BRAND MICRO WV..
TNKS
RABBANEES
Nov 11, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
840 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
