Question about SuperMicro H8DAE Motherboard
H8DAE-0 Fan issues, stopping and starting.
I have an H8DAE-0 board installed in my system and the fans will come on for a few seconds and then stop. I checked the BIOS and it is set for continuous fan power. The fans only kick in when the system is starting to overheat (72C) and then stop right afterwards. Lowering the overheat temperature is not an option. I have another system with the same components and its fans run all the time. I have double-checked the power connections and all the fans are plugged in independently so I don't think the fans themselves are an issue. There are stand-offs under the board so I'm fairly sure that it's not a short happening under the board. Any suggestions are greatly appreciated.
  • Mike
    Mike Aug 22, 2007
    Well the kicker of the whole thing is that the motherboard IS reading the temperatures correctly and tells me when the fans are on and the RPM they are at.
    It will display the temperature slowly creeping up to 72C (overheat temperature in the BIOS) and then the fans kick in and lower the temperature to around 55-60C, then shut off and repeat the cycle. Meanwhile, the system stays on and operates just fine so I'm not too sure of it being a processor fault.
    However, I'm still leaning to agree with you that it is a motherboard issue of some kind and I will swap it out when I get a chance and post back the results. Sadly I was secretly hoping for an easy answer like a jumper configuration of something. :D
  • Mike
    Mike Aug 29, 2007
    Although this was probably the toughest motherboard I've ever had to replace thanks to the 3 power supplies, 6 fans, cooling assembly and air cowl, the motherboard change did indeed take care of the problem. Thanks!
    President:
  • 2,961 Answers
Sounds as if you have a motherboard fault or a processor fault, as, if the processor is faulty, everything will stop, especially if the temperatures arent being read correctly by the motherboard causing the system to shut down before any damage is done.. It's a process of illimination i'm afraid
Posted on Aug 22, 2007
When cooking the fan doesn't run anymore. When I start cooking food the fan used to start right away, now it runs for a few seconds then stops but the food is still being heated.
The fan, a door switch, or control board relay may be causing the fan issue. Running the MW without a fan will not only cause steam buildup inside the cavity, it will cause the magnetron to overheat. If the MW has a thermal protector on the mangetron, it should shut the oven off when the temperature gets too high.
Nov 08, 2017 | Microwave Ovens
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Medion MED MT503 won't start or go through p.o.s.t.
When you say "fan" do you mean case fan or CPU fan? Almost sounds like the CPU fan is inoperative and the system is shutting down on CPU overtemp, then trying to restart.
Aug 01, 2014 | Medion Computers & Internet
Why does IBM fans stop spinning after opeating system loads?
Some system fans start when powered on as a test then go idle till needed went gets hot.
If they don't come on then it could be a bad capasitor on the main board.
Aug 28, 2012 | IBM Computers & Internet
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
SuperMicro H8DAE Motherboard Logo
174 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
